11-20-2008, 06:34 PM | #721 | |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
I know http://www.rpphobby.comhas has it. skid: http://www.shop.rpphobby.com/product...productId=1135 Link 7x50mm: http://www.shop.rpphobby.com/product...productId=1140 Link 7x60mm: http://www.shop.rpphobby.com/product...productId=1141 | |
11-20-2008, 07:57 PM | #722 | |||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
You can pretty much buy all the parts for the SWX kit separately if you want. | |||
11-21-2008, 02:54 PM | #723 |
thanks for both replies. Is the width of the SWX skidplate 50mm or 60mm? ( just want to be sure to buy the correct size posts. Those things are stupid expensive at $3 a piece)
11-21-2008, 02:58 PM | #724 |
Pebble Pounder Join Date: Oct 2007 Location: Bay Area
50mm wide. 60mm would be used for the upper links with the stock 3-link configuration.
11-21-2008, 09:21 PM | #725 |
Newbie Join Date: Feb 2008 Location: Wheaton
Bender i have a problem with my swx chassis plate the right side back part of it is bend to the back what can i do??
11-24-2008, 02:26 AM | #726 |
Pebble Pounder Join Date: Dec 2007 Location: CA
I plan use R2 + dig on SWX, Can the stock AX-10 shaft fit nicely in ? Or do I have to mod ?
11-24-2008, 09:09 AM | #727 |
Quarry Creeper Join Date: Apr 2008 Location: Carson City
Just woundering if anyone has tried to run bent links on there SWX?
11-24-2008, 09:23 AM | #728 |
Quarry Creeper Join Date: Jul 2008 Location: Garden State
| You do not need the bent links for this chassis. My SWX goes where my ARTR cannot Last edited by liketocrawl; 11-24-2008 at 03:00 PM. |
11-24-2008, 07:07 PM | #729 | |||||
11-24-2008, 07:13 PM | #730 |
Rock Crawler Join Date: Jun 2008 Location: dublin
BENDER!! CAN YOU RUN BERGS AXLES ON THE AXIAL SWX CHASSIS ?? THANKS FOR THE INFO |
11-24-2008, 07:19 PM | #731 | |
Here's a link to one SWX Berg build. tunner's SWX berg | |
11-24-2008, 10:00 PM | #732 |
I was thinking about running droop front , rear sprung setup, losi shocks. I was woundering if it would be worth trying? thanks
11-25-2008, 06:19 AM | #733 |
Quarry Creeper Join Date: May 2008 Location: Ontario
Can you run a mirrored axial tranny with the SWX?
11-25-2008, 05:01 PM | #734 |
"Bender", one last question. Will the new SWX skid plate mate up with your older SW3 chassis plates? ( are all of the holes in the same relative places?) Thanks for being so availble to answer everyone's questions. |
11-25-2008, 07:42 PM | #735 | |
I'm not sure on this either. Yup, it'll bolt right up. | |
11-25-2008, 08:19 PM | #736 |
RCC Addict Join Date: Dec 2007 Location: Chuck Chuck Chuckin Rocks.
Hey Brad, I'm having a problem that I think only a field test will be able to correct. Honest!!!!! Any chance you can set it up to come and help? JC |
11-26-2008, 08:46 AM | #737 |
11-26-2008, 09:42 AM | #738 |
Snapped a pic of my 4-link plate install in the rear of my rig. Here's a link with more details on the alternative link set-up these plates can provide too. Axial Bender Customs 4-link Plate |
11-26-2008, 10:02 AM | #739 |
I was woundering if you like running the same size uppers and lowers in the rear? Whats the advantage. thanks
12-09-2008, 10:52 AM | #740 | |
There's a bunch of good info here on link set-ups. 4-Link 101? Info on adjusting anti-squat. Adjusting anti-squat? Anti Squat and Suspension Tech | |
