10-12-2008, 11:23 PM | #21 |
| unfortunately not. That won't happen until I change out my links, or shorten the ones that I have. Currently my uppers and lowers are too long. Do you have any suggestions on some links that would make me legal? |
10-13-2008, 06:09 AM | #22 | |
Tanis used Traxxas 5318's and came in legal, could try those. Yotachump CDW proto chassis his build Yotachump CDW proto chassis if you still want bent links for breakovers you can bend those. | |
10-13-2008, 10:12 AM | #23 | |
thanks | |
10-13-2008, 11:47 AM | #24 |
Rock Stacker Join Date: Feb 2008 Location: Jacksonville, Arkancrawl
Rigs looking good man! Hope to see you make it back to Jacksonville, AR for a comp or gtg. I think we are having another gtg on Nov 1st.
10-13-2008, 01:29 PM | #25 | |
Rock Crawler Join Date: Dec 2007 Location: 10 a see
10-13-2008, 02:54 PM | #26 |
okay thanks! do you guys think that I could get by with my dremel rotary tool? hahaha i'm a little lacking in the tool department
10-13-2008, 03:00 PM | #27 |
Yea! if you have a cut-off wheel for your dremel. I use mine for a grinder very often. when I dont want to go outside to use the real one. Or you could use a tubing cutter, I have done that making custom links also.
10-13-2008, 03:18 PM | #28 | |
thanks a bunch for the info thanks man! Ihope to make it back soon. I have a bunch of new goodies to test out! | |
10-14-2008, 08:52 AM | #29 |
I cut my lowers links last night and changed my uppers. My WB is legal now. This CDW chassis performs so much better than the stock Axial. This chassis is awesome! I still need to tinker with my front foams a bit. When digging with the rear locked, my fronts don't load up as much as I want them too. |
10-14-2008, 05:46 PM | #30 |
10-14-2008, 07:07 PM | #31 |
Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
look good, when are ya goin to test it?
10-14-2008, 07:11 PM | #32 |
Rock Stacker Join Date: Aug 2008 Location: Lincoln
Those jack stands crack me up. Where did you get those?
10-14-2008, 08:11 PM | #33 | |
| Quote: I've been testing it as much as I can. I just need to find a way to get this lipo mounted somewhere on page 1 of this thread Last edited by helhedded; 10-14-2008 at 08:25 PM. | |
10-14-2008, 08:36 PM | #34 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
10-14-2008, 10:43 PM | #35 | |
Do you have any suggestions on link/shock placement? My suspension is real stiff. it wants to flip over easily, and the shocks don't want to compress all the way (without force) at full flex. Im using 30wt oil, and my shocks are limited about 5/8 under the pistons. I tried spacers on the upper shock mount, but the problem was still there. here are some pics Last edited by helhedded; 10-15-2008 at 10:59 AM. Reason: added some better pics | |
10-15-2008, 10:57 AM | #36 |
I picked this up yesterday |
10-15-2008, 12:01 PM | #37 |
TEAM RCC Join Date: Jul 2006 Location: Novato
space the top of the shocks out some or loosen the up the fuel tubing thats what i would try |
10-15-2008, 12:11 PM | #38 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
10-15-2008, 01:01 PM | #39 | |
tried it once, but trying again won't hurt I suppose. thanks duders I'm also going to try to run all of my uppers straight, and see if that helps. list to do: Space out shocks run uppers on the outside re-drill skid ( I drilled my holes way too far forward. I have maybe 1mm of space in between my pinion and frame ) Last edited by helhedded; 10-15-2008 at 01:04 PM. | |
10-15-2008, 01:09 PM | #40 |
