04-23-2009, 09:29 PM | #161 |
| Thanks man! It was nice meeting you as well. Sorry we didn't have more time to hang out. I was either running around or really tired |
04-23-2009, 11:07 PM | #162 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
Lid looks good as allways Brandon |
04-24-2009, 06:55 AM | #163 |
Rock Crawler Join Date: Sep 2008 Location: Utah
Lid and wheels look killer!
04-24-2009, 07:37 AM | #164 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
What maxamps battery are you running in the front axel? By the way new body looks good. |
04-24-2009, 08:42 AM | #165 |
| Thanks James Thank you! That is a 860mah split pack. Going to a 1100mah now. I will have to move the servo and battery in and slightly over the diff now. Its worth it to get the narrower stance though. |
04-24-2009, 09:49 AM | #166 |
You can't even tell it's a split pack where's the other battery lololol. Yea am gonna go with a 1290mah Capacity 7.4 Volts 30mm X 49mm X 25mm, the measurements fit just right on the front plate. I was running a 2200 but now with the mods I have done to my steering and the way I have my rig setup have to run those big puppies on my rear bender 4 link plate. and am afraid that with a rollover a tumble the battery will come loose. |
04-24-2009, 12:51 PM | #167 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
On the front axle, is the servo a direct mountto the axle or do you have a plate mounted to the axle housing and axle c
08-03-2009, 02:43 PM | #168 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Nothing new :? NO new picture's |
08-03-2009, 03:56 PM | #169 |
08-03-2009, 04:06 PM | #170 |
Shocks installed. They work extremely well. I think I am going to pick up another pair to run in the back of my Slash too, they are soo smooth and perform flawlessly. VP Dig installed. I love it, not a single issue while driving. Super easy to install too I am currently running it without any grease but I see no wear on the teeth of the drive side. The servo is overkill, but if I am going to run a full size servo I might as well use some power. Rear 4 link, been messing with different setups for a while now. I keep coming back to this configuration. Overall the rig feels planted on climbs. Also lightened the wheels somewhat. Last edited by Brandon; 08-03-2009 at 04:22 PM. |
08-03-2009, 05:13 PM | #171 |
08-03-2009, 10:01 PM | #172 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
Nice looking build Brandon, but yours always are. I just ordered a VP dig and was wondering if your trans is "mirrored" or just fliped 180 in the frame. Thanks Bill
08-03-2009, 10:34 PM | #173 |
Quarry Creeper Join Date: Jun 2009 Location: Tri-Cities
nice rig really looks GREAT |
08-03-2009, 10:39 PM | #174 |
08-03-2009, 10:54 PM | #175 |
Quarry Creeper Join Date: May 2008 Location: looking for sponsors
looks great Brandon i run the vp dig and it works awesome i just use the recommended 3 drops of 3 in 1 oil and its super smooth i switched to rovers after my cpds cut into my chisels so Nathan sent my chisels to pro-line for warranty and i have some ace's foams on the way im eager to try them again still running stock chisel foam? |
08-03-2009, 11:24 PM | #176 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Hi mate Do you have any close up pics of how and where the servo is mounted? I absolutely love the steering set up and would love to gain inspiration from the design (ie copy). The rig is well set up too. Thanks Kieren |
08-04-2009, 08:31 AM | #177 | ||
Thanks Nick, yeah I went back to the stock foam after I took some weight off. Hey Kieren, I have some older pictures that I might be able to dig up. Right now I am running a different setup up front that I cant quite share yet. Soon though | ||
08-04-2009, 11:25 AM | #178 | |
08-04-2009, 12:29 PM | #179 |
Best I can tell from the above pic's. Looks as if the BTA is still present but changed slightly. Everything looks higher mounted, servo is on the other side and judging that the battery is still mounted on the axle as well. Great build. Keep us checking in
08-04-2009, 03:33 PM | #180 |
Yeah I would like some of the older ones as on page 6. I have pretty much figured it out, so don't worry if you can't find any pics!! Kieren |
