04-02-2010, 01:43 AM | #161 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
looks like these are closer in my future then i thought ha today i was out back messing around and all a sudden no locked front took a closer look and snap the axial hd cvd shaft right at the bearingin the c lucky i had a spare for time being but ive had but luck with cvds mips are junk even bent a set of those, chewed up a set of axial stockers and no broke the axial hd ones looks like ill be ordering a set of these sooner then i thought can wait what are the mods i need to do to the gear, and is there anything else i need to mod? thanks |
04-02-2010, 04:46 AM | #162 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
the ring gear needs to be opened up to 6mm and the hexes need drilled. i think you can buy the hexes though
05-02-2010, 11:19 AM | #163 |
I had to shorten one of the axles about 1/32" other than that the kit is awesome. TCS is sold out of the super 300 hexes where else can I get a set, I drilled out the stock ones but the fit is sloppy and causes some wobble.
05-02-2010, 01:10 PM | #164 |
I believe I saw a post that TCS would have more hexes soon, only other place to get them that I know of would be direct from SDS. It's been about six weeks since I've posted in this thread, my bearings still haven't moved any and the C's are still rock solid after adding the extra setscrews. The 300's keep taking beatings and begging for more. I've ripped my 8711 off the servo plate and turned my BTA link into a pretzel, used a 8 foot high gate as launch ramp yesterday and the 300's keep laughing at my abuse. Last edited by indiana mudcat; 05-02-2010 at 01:12 PM. |
05-02-2010, 01:22 PM | #165 |
i have also been running these since the first post of mine in here. my bearings dont move and i have taken them out of the axles to clean them once and they still feel just as smooth as when i pulled them out of the package
06-21-2010, 08:06 AM | #166 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Is anyone other than tcs selling them?
06-21-2010, 11:05 AM | #167 |
I can't keep one of my bearings in, I have glued them but one always comes out. That issue aside they are awesome, I have bent aluminum servo horns and had to upgrade to aluminum servo mounts, but the 300's just ask for more. |
06-21-2010, 11:18 AM | #168 | |
Rock Crawler Join Date: Dec 2008 Location: dallas
| Hobbytown, and T1E, soon to add RPP, and MSD. CKRC has chosen for the second time to no longer carry my products. Quote:
Have u tried using the locktite? The locktite is meant to adhere the bearing to the shaft and not the housing. That should cure the issue | |
06-22-2010, 02:34 PM | #169 |
Pebble Pounder Join Date: Mar 2010 Location: Boston
I'd be interested. Whats the current price range set for?
06-22-2010, 03:24 PM | #170 |
06-28-2010, 10:40 PM | #171 |
06-28-2010, 11:31 PM | #172 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Hey man any news on my PM's
07-02-2010, 12:58 AM | #173 |
whats the best drill bit to get thru the hd gear set to widen the hole to 6mm?
07-02-2010, 03:36 PM | #174 |
Quarry Creeper Join Date: Oct 2008 Location: florida
i had to use a dremel tool with a chain saw sharpening bit, that was after ruining a few bits It doesnt have to be perfect since it slides in the locker. You shouldn't need to shorten any of them. interview Motorman: They are nice to have but the price is ridiculous. but i bought them anyway Super 300: |
07-02-2010, 05:35 PM | #175 |
thanks i just picked up a carbide tipped bit and ima see if thatll work since last night i tried just any ol steel bit and the gear was barely scartched
07-02-2010, 08:06 PM | #176 | |
The loctite I put between the bearing and shaft on 3-12 is still holding strong. Still no issue's with these, I competed in the Rox around the Clox 24 hour event last weekend and drove all 27 courses over the 24 hours, threw tons of abuse at the truck and the 300's took it all. I did snap a straight rear shaft on one eight foot fall on the 26th course I ran, even with the double setscrews in the C's they were wobbling pretty bad by the end also. No way I could of made it threw all the binds, jumps and falls I put the truck into that night without the 300's, I figure I would have broke 15-20 Axial CVD pins plus a few shafts and cups in that time. | |
07-05-2010, 09:49 AM | #177 |
awesome i tried that the carbide bit and nothing ima run to the hardware store and see what i can find
07-05-2010, 11:30 AM | #178 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Just a thought what about a small e-clip groove? to keep the bearing in place... |
07-05-2010, 08:16 PM | #179 |
07-05-2010, 10:37 PM | #180 |
After I move all of the shafts that I have from the first run then I will make the proper changes to the shafts and they will have a machined shoulder to retain the bearings though the loc-tite definetely will keep the bearings in place as Indiana Mudcat was saying.
