03-13-2010, 08:10 PM | #141 |
A little testing last night and 6 courses today and the bearings didn't budge any, not sure if it was the loctite or the extra setscrews but the C's are still tight after a heck of a beating so the extra setscrews deff helped that. Picked up the 9901 dremel bit after the comp so I'll see how it does on the HD stock ratio gears tomorrow.
03-14-2010, 07:57 AM | #142 | |
03-14-2010, 01:14 PM | #143 |
| I can take one but it's pretty simple, I have the Axial clockable C's and just put 3x3mm setscrews in the empty holes. When I first put the C's on they wobbled after the first course same as the CKRC's I had been running for a year, now there nice and tight.
03-14-2010, 01:34 PM | #144 |
Thanks I see I thought you had installed a set screw on the bearing to help hold it in place after full assembly so basically your Axial Cs and red loctight that and thats working for you?
03-14-2010, 02:24 PM | #145 |
Yes and I was very happy that the C's actually stayed tight.
03-14-2010, 06:02 PM | #146 |
Cool I'm running Axial Cs and knuckles and I hope mine hold tight like yours with just the red locktight. How much run time do you have on them? |
03-14-2010, 06:23 PM | #147 |
About 10 minutes at home (digging at full throttle with an 18.5) and 6 courses with a lot of wheelspeed used, before I added the setcrews my C's would wobble a little after 1 course though.
03-14-2010, 06:56 PM | #148 |
That sounds like a good test.
03-17-2010, 08:05 PM | #149 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
First impression: Mine just arrived in the mail today and the pictures don't do justice as to how stout these are in comparison to the MIP or Axial versions. Narly1 |
03-17-2010, 09:09 PM | #150 |
I installed 300s today everything went smoothly I used red locktight and I'm not looking forward to getting them off. I had to use my Panavise to get them to seat all the way they are definatly on. One drive shaft is a tiny bit long the knuckle doesn't swing freely enough I intend to take a little off the shoulder of the axle that goes into the locker with a file. A straight carbide Dremel bit makes qwick work of enlarging the center hole in the hardened ring gear. I'm waiting on some zero Akerman knuckles but even with the high clearance Axial knuckles the steering is much improved. It's a nicely done kit and was fun to install it also adds some nice low weight in the front as a added bonus.
03-17-2010, 09:27 PM | #151 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
What's everyone using to make the holes in their HD/Underdrive/Overdrive gears? A drill or a Dremel?
03-17-2010, 11:58 PM | #152 | |
RCC Addict Join Date: Jun 2005 Location: Prosser
03-18-2010, 06:26 AM | #153 | |
Thanks Jeeper gotta do something the bind gets worse as the steering turns tighter the othe side is totally free. | |
03-18-2010, 07:10 AM | #154 |
I used a dremel. On the subject of bearing retention, I'm laughing all the way to the bank. I'm using RC4WD C's and they are designed such that they capture the bearing in the end of the axle housing. No loctite or CA needed! Narly1 |
03-18-2010, 07:30 AM | #155 |
I think the way I will take is file the square shoulder end of the axle that goes into the locker unless I hear other wise from SDS Customz.
03-18-2010, 09:03 AM | #156 |
Rock Crawler Join Date: Jun 2008 Location: South Ogden, Utah
| carbide drill and a file
i used a carbide drill on my axial overdrive gears, cut like butta, then a regular file on the tang of the shaft that was approximately .020" too long. smooth turnin now
03-18-2010, 03:48 PM | #157 |
Rock Crawler Join Date: Dec 2008 Location: dallas
As ive posted before, I ran the tolerances tight on the shaft length to keep engagment to a maximum. they fit perfect in all of the test housings . though we have found several housing differances of over .020. A few guys have acctually had issues getting the lockers to fit. since the bearing cutout in the locker area where molded tighter, in some cases. I wont settle on a sloppy fit! I think we all agree that sloppy sucks in any venue With that said if u question having to trim or shave a little hear or there then pm me and we will discuss it. otherwise, just use common sense.
03-18-2010, 05:20 PM | #158 | ||
03-23-2010, 08:23 PM | #159 |
Stormin2u- I love the sig line!
03-25-2010, 06:33 AM | #160 |
Hey thanks it's something that Pat 62PYRO came up with and it's true I take my time with everything I'm not big on speed building it usually Leads to problems. By the way love the axles I've ran a few packs and everything is working perfectly and the steering is awesome. |
