08-20-2010, 07:33 PM | #201 | ||
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
Casey Quote:
I got it running last night again with the new motor and ESC. I love my steering too. Last edited by KC_JoNeS; 08-20-2010 at 08:26 PM. | ||
08-20-2010, 08:11 PM | #202 |
Well, I romped it around the living room for a few minutes last night. Thoughts for the moment: 1. Lower links are a bit too close together, and the driveshaft touches one during articulation. I could also clock the axle a bit more. 2. Steering feels good right now. I will put bushings in the tie rod, and give that a try too. I have a few to play with. 3. The speed control with brake...WOW! The BR-XL is awesome! 4. The motor is super controllable. I now understand why people would go for a 35T. These things have so much control in any position. But, mine is sparking, which means I need to advance the timing just a bit....maybe 2.5 degrees or so. 5. Got to finish the wiring cleanup. 6. Will get dig installed when it arrives. Casey Last edited by KC_JoNeS; 08-20-2010 at 08:31 PM. |
08-20-2010, 09:12 PM | #203 |
Quarry Creeper Join Date: Jun 2010 Location: Ravenna/ Sault Ste. Marie
i like em
08-20-2010, 10:47 PM | #204 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
looks good. as for the steering linkage, i used axial knuckle bushings in my bta, however i found that if i left the screws slightly loose so the bushings moved free i had a fair bit of slop, and tightened right up it wore the link bar out fairly quick, and im again faced with sloppy steering. i plan to use rod ends and build a different link
08-20-2010, 10:57 PM | #205 | |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I think what it really boils down to is 'looks over performance' in the long run... what looks good isn't always going to last. I guess for bashing around the local rock pile a lil slop isn't the end of the world, but then again im picky Not bashing your design Casey, just looking for ways to improve it. I did see one guy on his MOA who mounted the servo on the draglink itself, it was probably the BADDEST thing ive ever seen, now that got me thinking with this stuff | |
08-20-2010, 10:58 PM | #206 | |
08-20-2010, 11:06 PM | #207 | |
Thanks. Casey | |
08-21-2010, 12:27 AM | #208 |
Well put, I "help" (ok im a student...) in a machine shop class and lets say some of these people can be interesting when you tell them 'no not to do it like that" I will say experimenting tells you "what works and what doesn't" I think your best bet against friction is: Bearing/teflon "bushings" on one, or both sides. The bearings are there for a reason, as well as the teflon "bushing" (very slippery right ) should deal with any issues. Aah do remember if you clock in negative caster (eeh -10* works good from vert with the knuckles) you WILL have to deal with the "tierod" banging into the shocks more. There are ways around that, but just a warning Negative caster helps improve turning by providing more traction, even though i never increased my throw, putting in negative caster sure made a heck of a difference in how my car turns, without CVD's or a super powered servo |
08-21-2010, 01:03 AM | #209 | |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
08-21-2010, 01:08 AM | #210 | |
08-21-2010, 01:15 AM | #211 | |
Alrighty then, I guess we'll all be kept "in suspense" till your baby is ready. For KC: You could try a combination of an Axial steering bushing(I call them "top hats" for obvious reasons) along with a steel insert (simple tube)pressed into the aluminium of your sexily curved tierod. It would take some work, but when greased, it would last a lot longer before slop sets in. I tried flange bearings once, but stay away from the tiny Duratrax 3X6 ones, they are much too weak. Oh yea, forgot, if you ever break the 3 Racing cvd pin, just get some .078 music wire, 10mm long fits just right Last edited by gunnar; 08-21-2010 at 01:25 AM. | |
08-21-2010, 01:29 AM | #212 | |
Thanks for the head's up on the CVDs. | |
08-21-2010, 10:41 PM | #213 |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
I thought that the esc you have was rated for a 6s. How come you had to put a BEC in it?
08-21-2010, 10:50 PM | #214 | |
Casey Last edited by KC_JoNeS; 08-21-2010 at 10:57 PM. | |
08-21-2010, 10:57 PM | #215 |
| Oh, so it can handle the volts but not the amps it drawing from the two servos combined?
08-22-2010, 12:17 AM | #216 |
the 7950 is a high voltage servo, it can take 7.4 volts. running the bec direct to the servo will allow it to run at its max voltage for optimal speed and torque. the 5645 on the other hand does not run on more than 6 volts, so running the internal bec on the esc will provide proper voltage for it and the receiver
08-23-2010, 07:27 AM | #217 |
Well, I went to the store today and got some drill bits and misc. crap. The drill bit needed to use the Axial top hats is 4.5mm. Here is the top hats pressed into the tie rod. The knuckles are threaded, but just to be sure, I mounted some nylocks on the bottom along with some blue loctite. There is also some plastic washers on the top of the tie rod because the screw stays set in the knuckle. Next up is the rear end. I made the following changes: 1. Installed HD 43/13 gears for underdrive. 2. Installed 3Racing CVDs in the rear. (decided not to run these in the front) 3. Installed 3Racing dual bearing axle lockouts. I got all the wiring done, and buttoned up a bunch of issues. I flipped the shocks back to upright as I needed a bit more clearance for the large diameter lower links. I adjusted the weight in the wheels. The fronts have 2 ball bearings, and the rears have none. My overall weight right now is just over 6.4 lbs, and that is without my dig and second servo. :shrug Last edited by KC_JoNeS; 08-23-2010 at 07:30 AM. |
08-23-2010, 10:12 AM | #218 |
Got some more detailed pics up close. |
08-23-2010, 02:00 PM | #219 |
Lookin goooooood How much you running in terms of weight in the tires, or any So hows the Delrin work, or yet to try it, and nice work using the top hat bushings... now we need video proof |
08-23-2010, 06:51 PM | #220 | |
I have yet to romp on this setup. I just got it buttoned up last night, and it was raining. I did get a bit of couch crawling, but that is not the makings of good video. I am looking for an HD camcorder. Will try to pick one up (convince the wife to buy one) this weekend. Casey | |
