11-10-2010, 02:53 AM | #261 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| nice
Ya a lot of presure on the font end with a dig .I have the 225 mg and broke the mini servo bracket from the flex .I built one from angle alum and it is much better plus it holds some some of my elctronics.I will post pics when i get my new sssr chassie and parts.your froger looks sweet Kc.And if i could aford to fly to china i would crawl with ya.
11-10-2010, 06:14 PM | #262 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
I spent a little time last night tearing down the wheels. I removed the Chisels and Proline foams, and installed the new Sedonas with 5.5" double deuces. Then I painted the outer plates purple to match the skins and tie rod. The front wheels have 3 bearings installed, and the rears have none. This should give me a good variation of weights to run for comping. Also, I plan to use 2 of my B.A.M. wheels in the rear with rovers. The overall weight right now with these Mayhems is 6.92 lbs with no battery. |
11-10-2010, 06:24 PM | #263 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Looks cool man, I like the purple rings. If you like you can lose 75% of your bead lock hard wear too, to make changing weights easier.
11-10-2010, 06:29 PM | #264 | |
As I see it, I have the front wheels and tires with weights, then I have the rears with no weights that I can still use as fronts in combination with the BAM wheels in the rear. I should have enough options for our little outing next month. She is all tuned as well. Her movement is buttery smoothe. Casey | |
11-20-2010, 05:27 PM | #265 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
11-22-2010, 11:26 PM | #266 | |
I have the 4 steer frogger done the correct way though...and the steering goes until the tires hit the springs. If you want to see lock to lock, check out the thread by highlucks. His SSS-R uses my tie rod, and it goes all the way. Casey | |
11-23-2010, 05:35 AM | #267 | |
Thanks Casey | |
11-24-2010, 01:28 AM | #268 | |
11-24-2010, 05:32 AM | #269 | |
jeff | |
11-24-2010, 12:24 PM | #270 |
The tie rod barely touches the spring in either direction. I made my tie rod thick so you can grind it down where it rubs....if needed. Casey |
11-24-2010, 06:02 PM | #271 |
If you look closely here, you can see that the tie rod is super close to the spring, and this is at its closest. Also, remember...you can adjust this by adjusting the length of your uppers compared to your lowers. Casey |
11-24-2010, 06:03 PM | #272 |
And here is a new shot from this morning of my white frogger with his new shoes on. ATI Turbines...badass. |
11-25-2010, 06:05 PM | #273 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
man, those turbines are just plain sick! Both rigs are lookin pretty sweet bro. How do you like the sedonas compared to the rovers? |
11-25-2010, 06:36 PM | #274 | |
The Turbines...yeah, they look badass. Casey | |
11-25-2010, 07:40 PM | #275 |
Looks cool man, white on white.
11-25-2010, 07:57 PM | #276 |
11-25-2010, 08:32 PM | #277 |
Rock Stacker Join Date: Mar 2010 Location: washington
