10-11-2010, 08:27 PM | #201 |
RCC Addict Join Date: Jan 2010 Location: Dallas
OK. I did the thrust bearing mod tonight. Way cool. I am a little bit concerned about pitting the bearing seats but I like the smoothness of it. Here is your shock link pic. Now I noticed your shocks are mounted inboard so this might not help, but here is how it goes. Two traxxas hollow balls, with the schrink wrap over the outside of the hollow balls. You want the shock top to sit in the valley created by the hollow balls. |
10-12-2010, 04:06 AM | #202 | |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
10-12-2010, 07:52 AM | #203 |
I am not sure it has "helped" steering, but taking some bind off the servo was definitely accomplished. My BTA kit and also having aluminum C's and Hubs, sure seamed to put a lot of stiffness in the setup prior to putting the bearings in. I just did this last night so I have not driven it, but I do think it will take some load off my servo. The one thing going through my head right now is steering throw. I was looking at some of the XR10 threads with the VP knuckles and the throw is huge! I then went and looked at my rig and my throw while decent is nothing like the XR's. My main limiting problem is my shocks, well and my servo (tire rub). I have been stewing over maybe a slightly wider front stance or moving my links/shocks around. Right now my thought toward a slightly wider hex is winning out. Any ideas on a hex that will work? Most I have seen listed here are way wide.
10-12-2010, 08:03 AM | #204 | |
10-12-2010, 08:29 AM | #205 |
Interesting. I am running the same red wideners on both my kids mrc's but I was worried they would widen things a little to much to make it through gates on my 2.2. Any chance you know your overall outside to outside front track width? Forgive me if that is a little personal!
10-12-2010, 08:53 AM | #206 | |
10-12-2010, 10:24 AM | #207 |
I think the track width of mine is the same now without extenders. I will probably take the extenders off my kids truck and see how it works out. I can't remember what the gate width is at a comp, but did you notice any difficulty with the extenders and your old setup? I am guessing the rear width is the problem, and with the stock setup you are ok on that. Keep in mind I may have given myself up as knowing a ton about the FB and comp setups and I do a ton of comp worthy practice on my test course but I have only done one comp and I realized my setup was all sorts of wrong at that one.
10-12-2010, 10:57 AM | #208 | |
10-12-2010, 12:57 PM | #209 |
While I was at home a minute ago I measured up my axles and was shocked to see that with the DNA assassins and Sedonas, I am sitting at 10 1/4 wide. Time for the extenders!
10-12-2010, 01:16 PM | #210 | |
Edit: sorry dude, thats someone else getting DH's. Last edited by billj; 10-12-2010 at 01:19 PM. | |
10-12-2010, 01:20 PM | #211 |
The wideners are much more pocketbook friendly and to be honest I really like my DNA wheels. They are heavy as crap but my truck drives really well with them. It stays planted like a oak tree. I also just purchased the DNA's a month or so ago so I am dancin with the one I brung.
10-12-2010, 01:37 PM | #212 | |
10-12-2010, 09:22 PM | #213 |
Well I ran the truck tonight. Wideners (better turning) and also with the thurst bearings. I had a good run going. pushed it pretty hard on a climb. After a few passes through a 5 gate setup I noticed something did not look right in the steering. Grabbed my truck and my steering setup had come unglued. Somehow I found the thrust bearing parts laying on my deck next to my rock pile. Got it all back together with a safety locking nut and whalllaaaahh.
10-13-2010, 04:04 AM | #214 | |
10-14-2010, 03:47 PM | #215 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Hey man looking for more info on your wheels. Width offset f/r. Thanks man... looking to order some slw's with my vp goodies right away.
10-14-2010, 04:39 PM | #216 | |
10-14-2010, 04:48 PM | #217 |
Thank you sir!
10-14-2010, 04:50 PM | #218 |
10-18-2010, 07:59 AM | #219 |
Had a local comp yesterday in North Palm Beach. Finished 4th, top placing shafty. Missed third by 2 stupid gates.And i do mean "stupid" ,my fault not paying attention. I have problem of looking too far ahead,before my truck clears a gate. But i finished behind a berg(GST),xr10 (DickyT), and another berg(richardgarrett56). So it was not so bad. Maybe next time |
10-18-2010, 08:23 AM | #220 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
Congrats bud, glad to hear your showing those MOA guys that the fastback shafty is still tough to beat. Making the top MOA guys sweat w/ an ole shafty must be fun |
