03-19-2011, 12:36 PM | #1 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| fred0000's sportsman build
some of you may remember "fred000's tuber" it was a pretty slick crawler for what it was, I was a bit bummed to decide to part it out/take it apart to build a more "comp" sportsman rig, but I fell it will be a good step in the right direction, when I build the tuber I wasn't really interested in comps, now all I can even think about is comps. I started with a CF slingshot chassis I got from a member here, this chassis is awesome. I used all the stock axial links I had on my tuber, the lowers needed to be trimmed ALOT, still need a bit of trimming, but i'm still waiting for my m3 tap, my wheelbase is at 12.5" at ride, and about 1/8" longer compressed. so its close. I will have more pics and details throughout the build, i'm still waiting on a few things, but there is still a few things I can do while I wait. |
03-19-2011, 12:56 PM | #2 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
I want to see it with tires on it All kidding aside, it looks like a sick sporty in the works. Keep it coming man |
03-19-2011, 01:14 PM | #3 | |
a few more specs. CF slingshot chassis castle sidewinder ESC castle BEC hitec 7954SH servo tekin T35 motor overdrive front gears golden horizons C-Hubs golden horizons knuckles losi mini shocks losi grapler pro body MIP CVD's with gunnar pins MIP driveshafts spectrum SR3300T RX gunnar body mount 1000mah 3s lipo's stock Berg wheels pink dot rover's beef toobs in the front axle robinson racing solid outputs HR stainless steel idler gear Last edited by fred0000; 03-25-2011 at 10:49 PM. | |
03-19-2011, 01:44 PM | #4 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Wow that's amaaaaaaaaaazing! I think it needs some Delrin links tho [im addicted to that stuff for lower links, that's me though ] Why pink rovers, do they work good where your at or that's what you like |
03-19-2011, 01:54 PM | #5 | |
I went with pink rovers cause while waiting for my white rovers I went to the LHS one day and that actualy had a set of HB tires, they were pink rovers, they work great for me on my AX10, white rovers are on my XR10. installed my driveshafts, front angle is a little steep but should be fine. grapler body. with wheels/tires just for jeepkid I am using losi mini shocks, I filled a 3mm rod end and drilled it for the mini shocks, worked great, I have some 3racing mini shocks on the way that have a removable shock cap, it will get a rod end mod and inboarded on the chassis, for now fuel tubing bushings. | |
03-19-2011, 01:59 PM | #6 |
with wheels/tires just for jeepkid Why thankyou good sir. It looks awsome, your vision is coming to reality. Whats the beelly clearence? |
03-19-2011, 02:12 PM | #7 | |
that pic really shows how exposed the front driveshaft is, I hope it won't be to much of an issue. | |
03-19-2011, 03:47 PM | #8 |
You will have no issue with those MIP shaft on there. If you can clock the pinion angle a bit you would be good too. Get some of those clockable CHubs for it and you can mess with the C clocking.
03-19-2011, 03:50 PM | #9 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
Have you thought of modding the front axle with the beef tubes to get more clocking/make the driveshaft angle better Here is the mod i did on my sportsman rig (sporting your old tires) It makes the steering setup i little bit of a pain, but the extra clocking with the drive shaft angle up like that is soooooo nice. |
03-19-2011, 03:54 PM | #10 | ||
I may have to sacrafice some castor for a happier pinion angle. i'll have to wait and see till my new shocks get here and mod them. | ||
03-19-2011, 05:13 PM | #11 |
I have some home made axle tubes and I use them mostly for the ability to clock the front to gain extra steering. Nothing beats it |
03-19-2011, 09:24 PM | #12 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Looks the goods man, Some longer uppers in the front will help your pinion angle a lot. This will add negative castor to your Knuckles but that can be corrected with some of Casey/Gunnar's Beef Toobs. As for leaving your drive shaft like that because it is strong and can handle it. Thats not really the point, you want a level surface behind the axle the drive shaft will just be a pivot point to fall off and catch on. |
03-19-2011, 10:36 PM | #13 | |
thanks, there is a hole in the chassis more forward for the upperlink I will move the uppers to, it has beef toobs in it, I may consider clocking it more once its up and running. the finalized shocks will be a hair longer which kinda sucks, its high enough as it is, but we'll see what can be done once I have them in my hands. the drive shaft being an anchor was really buggin me, but I thought having that much castor was just awesome | |
03-19-2011, 10:40 PM | #14 |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
Very pimp! Me like. |
03-19-2011, 10:49 PM | #15 | |
03-20-2011, 12:29 AM | #16 |
laying the shocks down shouldnt be a problem, the suspension is way to soft though, I dont know if you can get differnt springs that fit the losi mini shocks, I may have to go with 3.5" big bores, I do have some 3racing losi mini shocks on the way with threaded shock bodies. here is a pic of a mini shock with 3mm rod ends on either end. and some "as it sits now" pics |
03-20-2011, 02:03 AM | #17 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
yes you can get different springs for mini shocks i say get a set of the mini t springs fronts and rears and use some plastic washers to make up your own dual rate since the mini t springs come in 3 stiffnesses and are readily available at pretty much any hobby shop
03-20-2011, 07:03 AM | #18 |
Wow man she is going to sit very tall, is there a way you can get you lowers parallel to the skid.
03-20-2011, 11:55 AM | #19 | ||
I got the body mounted up using Gunnars body mount kit. 2 posts in the back, one up front. also has XR10 wheels/tires mocked on so I can mark out where I want to trim the body. (the front of the body has been lowered since these pics) | ||
03-20-2011, 12:14 PM | #20 |
Yeah, on my body the servo and battery in front hit the body. It still works fine for me. I think you will be fine with it sitting lower in the front, still want to see pics of the body on it low. |
