01-22-2012, 09:04 PM | #41 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: my ax10.... let the modding begin!!!
im pretty sure the AE-2 ESC has a bec in it already.. but i could be wrong.. it was twitching and jumpy but then i put some new batteries in the radio (just changed them like a week ago and havent ran the truck all week) but the twitching and stuff stopped so that was pretty sweet.. well... i know we are never done but done to the point where i can stop modding for a while and just drive it. |
01-22-2012, 09:12 PM | #42 |
no im not, but im pretty sure that the AE-2 esc has a BEC already but i could be wrong too.. didnt get any pics of my crawler but a friend did so we'll have to wait for those.. here's a couple pics i got of the days event.these are all ax10's. this one is weird the rock was stacked and he was driving over them and this one followed him and landed pinned down the front end and stood there on its own.. you could have left it there all day with no problems!! he drove out of it and landed it too.. |
01-23-2012, 12:07 AM | #43 |
Quarry Creeper Join Date: Jun 2010 Location: Marsing ID
yes the AE2 has a bec... Im 99.99999 sure that all esc now days have them. most are 4.8volts.
01-23-2012, 10:51 AM | #44 |
thats what i thought but i wasnt 100% sure.. oh well quick swap out today and it'll be all good.. do you know if the AE-2 has a reset button?
01-23-2012, 12:23 PM | #45 |
finally got my 4 link plate from a friend so gonna do that soon as well and going to make a longer drag link and put it on the other side of servo. |
01-23-2012, 01:31 PM | #46 |
no... but you can adjust them with a castle link...
01-23-2012, 01:43 PM | #47 |
just gonna swap it out for my novak rooster. but the AE-2 will go into my honcho so if i have i'll just run an external BEC.
01-23-2012, 05:31 PM | #48 |
Quarry Creeper Join Date: Jan 2012 Location: on the other side of the tracks from baldy
the 645 is weak wanting to upgrade myself atleast 7955 but wanting the 7980
01-23-2012, 07:34 PM | #49 |
| Re: my ax10.... let the modding begin!!! ya i found the 645mg weak too.. i went with the 7955 and love it. plenty of power, remember the bigger the servo the more juice its gonna need. like i said earlier the AE-2 does not like the 7955, you'll have to either add an external BEC or upgrade the ESC. |
01-23-2012, 08:34 PM | #50 |
it was easier to swap out the whole battery plate then to try and peel off the AE2 off its plate.. so now gonna cut the tamiya plug off the novak rooster and wire it directly to the battery and add a new on/off switch because the last one crapped out on me... yay!! |
01-23-2012, 09:31 PM | #51 |
a little heat on the back side of the bat plate will usualy make the glue soft so you can pull it off... What do you mean by... remove the plug on the rooster & wire it directly to the battery???? How will you charge the battery? |
01-23-2012, 10:20 PM | #52 |
before i was running an adaptor type deal with a white tamiya plug on one end and a red plug (the same plug thats on the 3racing winch) on the other end so i could run lipo but if i cut the white tamiya plug off of the red/black power wires coming off the ESC and solder on one of them red plugs so i can eliminate the adaptor. guess i should of worded it different. a friend did this to my AE-2 ESC but now that i swapped speed controllers im gonna do it to my novak rooster. |
01-31-2012, 09:17 PM | #53 |
well i had plans to finish up the wiring on the rig today but mom dragged me into town for 4hrs this afternoon so it didnt get done.. hopefully tomorrow.
01-31-2012, 10:08 PM | #54 |
I use the mini deans connectors to wire the BEC onto my esc's... that way I can remove the bec easily... + they are supose to be very good conductors.
01-31-2012, 11:49 PM | #55 |
Rock Stacker Join Date: Nov 2010 Location: Montreal qc canada
the 645mg is weak but it's a suprising little servo i always have one at home when ever i need one on the fly or to test something it never fail me yet :P
02-01-2012, 10:56 AM | #56 |
ya i put mine on the shelf and will use it for testing. im running a 7955TG in this rig now and works awesome. |
02-01-2012, 05:14 PM | #57 |
well finally a day im not going to town so i just finished up the soldering and im moving my steering drag link over to the other side plugged in a battery out in the shop so if it didnt work it wouldnt burn the house down. pics in a bit when i get it back together...
02-01-2012, 10:30 PM | #58 |
she's back together now did some testing in basement. i was playing on the lino floor with a box of drywall mud and got the front tires to grip and drive up then drive sideways until the rig is just about to tip then put that $134 servo to use and wiggle it and the rig tips over onto the sidewalls of 2 tires without flipping over then you can drive around haha... one of my front driveshaft set screws loosened so only had 2wd so add some more locktite and gonna let it set overnight so i will get some video tomorrow.... got a couple pics of the esc and steering i will get them on the laptop and post them in a few mins. EDIT: here's some pics steering on the other side of the servo. also had enough stainless tubing to do the drag link in stainless. i cut the white tamiya plug off and added the same plug as my lipo's then covered them in shrinky dinky tube. before i was running an adaptor with a tamiya plug on one end and a red plug on the other. novak rooster crawler ESC has found a home in this rig. hopefully no more damn amperage problems.. Last edited by AX10wannabe; 02-01-2012 at 10:44 PM. |
02-02-2012, 08:32 AM | #59 | |
02-02-2012, 11:16 AM | #60 | |
| Re: my ax10.... let the modding begin!!! Quote:
all my friends and i try to run the same connectors so if one of us runs out of batteries we can borrow one and continue crawling. the batts are only a 2s but im running a 55t motor in this rig and my scaler. | |
my ax10.... let the modding begin!!! - Similar Threads | ||||
where should i begin? | tellicobeach | Newbie General | 4 | 05-20-2010 01:22 PM |
Let the mods begin! | mr.freeze | Axial AX-10 Scorpion | 30 | 12-20-2009 03:25 AM |
I should have bought an AX-10 to begin with... | warDialer | Axial AX-10 Scorpion | 14 | 09-12-2009 10:11 PM |
Let the hating begin..... | -w-designs | Paint and Body | 22 | 06-08-2009 12:15 AM |
