11-23-2012, 11:16 AM | #21 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
| Re: SuDu One - 2.2s / Sportsman chassis
I want one of these please! Looks great! Are you also making the upper link mounts for the axles? Thanks Ty
11-23-2012, 11:24 AM | #22 | |
RCC Addict Join Date: Jun 2009 Location: Australia
Looking good Tomi Sent from my GT-I9100T using Tapatalk 2 Last edited by Oz Bruiser; 11-23-2012 at 12:03 PM. | |
11-23-2012, 11:26 AM | #23 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
| Re: SuDu One - 2.2s / Sportsman chassis Those are also made.. look at the Dutch sporty build. Its also the SuDu chassis. But then normal with a body..
11-23-2012, 11:48 AM | #24 | |
RCC Addict Join Date: Oct 2008 Location: Finland
| Re: SuDu One - 2.2s / Sportsman chassis Quote:
Thanks for the interest! | |
11-23-2012, 11:58 AM | #25 |
| Re: SuDu One - 2.2s / Sportsman chassis |
11-23-2012, 02:10 PM | #26 | |
The chassis will be available as a base only or as a bodiless version. | |
11-23-2012, 02:21 PM | #27 |
I wanted to give you a look at how the chassis looks mounted up to a set of axles. Nothing is final here, I just used what I had laying around. The shocks are too tall so ground clearance is about 10-15mm too tall. I want to have the front of the skid plate down to 70mm and the front of the chassis angled down a little bit more. Shorter shocks are on their way which I believe will get me where I want. I will use the rear link mount that Douwe designed but will probably go for a slightly different mount at the front as I believe I will prefer to have the servo, battery and esc mounted above the front axle. Despite the temporary mock up I find the chassis has nice proportions. |
11-23-2012, 02:59 PM | #28 |
Looking great mate. That will go well locally. I'm sure there will be a few Aussies keen on this If you or Douwe can do the links in ti instead of alloy although I realise there will be a cost upgrade it will assist in sliding over rocks. What shocks are you running in the mock up? Is the chassis cab measurements all good for legalities to? The high pitched topper should allow good roll over recovery to. Though I do wonder if is to high maybe. Not sure if lowering the pitch of the A pillar would take it away and if the roofline was a fraction lower too. Sent from my GT-I9100T using Tapatalk 2 Last edited by Oz Bruiser; 11-23-2012 at 03:11 PM. |
11-23-2012, 03:38 PM | #29 | |
Douwe originally designed the chassis with the SCX shocks in mind. For the mock up I just took what I first could find in the garage. The fronts are 4" Traxxas Big Bores and the rears are 4" Losi Crawler shocks. I measured both shock pairs to be 105mm eye to eye. I have ordered 3.5" Big Bores and plan to give them the shock cap mod and adjust eye to eye length to 95mm. I think this will bring me close to the ground clearance I'm looking for. It should be. Here's a pic showing the dimensions. Width is 80mm. You will notice that the tall topper indeed makes the chassis 8mm higher than the minimum requirements. Rollover should be good on paper. But testing will tell. According to the 2012 US Rules bodiless chassis minimum dimensions are: ▪ 2.3.5 - 2.2 Crawler class bodiless 8" overall length, 3" overall width, and 3.75" overall height. 8" = 203.20mm 3" = 76.20mm 3.75" = 95.25mm I believe we can still adjust the topper if need be. Thanks a lot for your input, Ben. Last edited by Tomy; 11-23-2012 at 03:47 PM. | |
11-23-2012, 10:29 PM | #30 |
Quarry Creeper Join Date: Jun 2010 Location: Grand Junction
11-24-2012, 01:02 AM | #31 |
11-24-2012, 07:05 AM | #32 |
Ok thanks! I guess the title kinda confused me as well. Since it says both. Great looking chassis anyways!
11-24-2012, 08:21 AM | #33 |
Well this chassis can do both. It turns into a 2.2s chassis without the topper and hood . Instead of the topper you install two horizontal braces. Douwes Dutch Sportsman build shows the chassis built up as a 2.2s version.
11-24-2012, 09:48 AM | #34 |
Oh ok. Gotcha! Now I'm all straightened out!
11-26-2012, 01:09 AM | #35 |
Man, i think i have to convert my SuDu one to a bodyless also... It's looking so much better in real then on the drawing
11-28-2012, 12:38 PM | #36 | |
Got my 3.5" Big Bore shocks today. Couldn't wait and escaped to the garage to mod the shock caps for bind free movement. Now where is that 3.2mm drill bit? Found it! Drilling through the caps after I cut the stock mount of. Finished set. Did a set of Mini-T spring cups as well. And this is the stance now. After the cap mod the shocks ended up at 92mm eye to eye. That's 3.6". The front of the skid plate is now at 75mm. But the front axle is not clocked right and once that is done, the front will sit a little lower still. Probably close to 70mm, which is what I am aiming for, and I'll be able to raise the shock up one hole for a little steeper angle. | |
11-28-2012, 12:59 PM | #37 |
Looks like my work bench Tomi Rig has a really nice stance. Looking good. Can't wait to start tinkering myself :thumbup: Sent from my GT-I9100T using Tapatalk 2 |
11-28-2012, 01:11 PM | #38 |
| Re: SuDu One - 2.2s / Sportsman chassis Thanks! It makes me feel better I'm not alone with this mess. Sorry for the waiting time, Ben. I'll order up some cf tomorrow and try to get to work next week. |
11-28-2012, 01:35 PM | #39 |
That's ok mate. Got most of gear from my own built sporty I won the Nats with. Just got replacement ESC's from Oneten, though only need one of them. Only some VP gear and a few extra alloy screws needed, but good to go otherwise. Sent a pm regarding other parts I will likely need. Got two scale builds on and a wraith to tinker with in the mean time if I get board Sent from my GT-I9100T using Tapatalk 2 |
11-28-2012, 01:48 PM | #40 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
looks great Tomi:thumbup: Sent from my GT-I9300T using Tapatalk 2 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/413432-sudu-one-2-2s-sportsman-chassis.html | ||||
ZONACRAWLING • Ver Tema - mi nuevo 2.2 | This thread | Refback | 02-24-2013 02:50 PM |
