Thread: Dlux Sportsman build
Old 02-11-2015, 08:47 AM   #481
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Re: Dlux Sportsman build
Add some Delrin tubes and a truss.
Erik D_lux is offline   Reply With Quote
Old 02-11-2015, 08:47 AM   #482
Erik D_lux's Avatar
If you didn’t catch it, one of the biggest reasons for doing this axle was to get my perfect width. I struggled with the AR60 to get narrow enough and with AX/SCX axles, you’re just not wide enough and I didn’t want to run extensions. Now, I am exactly where I want since I can make the tubes any length. I can make these axles for just about any driveshaft car from Ultra4 cars, to Yeti rear, SCX10 and obviously sportys.
I am running close to 10.5" wide now. I have options to go as wide as I want or even narrower. This is the amount of scrub and width I wanted from the get go though.
Old 02-11-2015, 08:47 AM   #483
Erik D_lux's Avatar
I also switched out my brass knuckles for 7075 versions since I have so much weight below the knuckle, I don’t think I needed the extra of the knuckle itself. I also am testing out a newer version of attaching the loaded dice weights to the knuckle. It’s kind of super version meets bolt on version. So far I like it a lot because its super simple to move the weights back and forth since I can see myself slightly tweaking the track width in the front end.
Old 02-11-2015, 08:47 AM   #484
Erik D_lux's Avatar
Here are some pics I took while on the rocks. Thanks for checking this thread out and be sure to check the full write up of the 1808 axles in the Wraith section!
Old 02-11-2015, 10:57 AM   #485
DickyT is offline   Reply With Quote
Old 02-11-2015, 05:29 PM   #486
Now that's what I am talking about
Almost pm'd you, asking about doing delrin tubes on the 1808 axles once I saw them yesterday.. But, I figured I would wait. I knew you would release something like this, just didn't expect so soon.
Like I said about the yeti/wraith versions.. a sweet product like this from you doesn't suprise me. Simply amazing
Hittman is offline   Reply With Quote
Old 02-11-2015, 08:44 PM   #487
Awesome product awesome work...
cliff1119 is offline   Reply With Quote
Old 02-11-2015, 09:36 PM   #488
Because someone asked it about the wraith version, I gotta ask here. What does your complete front axle weigh in at?
Old 02-12-2015, 06:22 AM   #489
Erik D_lux's Avatar
Thanks man!
Weight is a good question.... I never did weigh it. It was in and out of my car so many times and I never had it "complete" out of the car really since this was the first I made. If I end up taking it back out, I will get a weight however,... I am not sure it will ever get done, I am thinking of selling this car.
Old 02-12-2015, 10:22 PM   #490
Selling? Awe man. But understandable with the lack of comp scene there in SLC.
Curcal is offline   Reply With Quote
Old 02-13-2015, 05:57 AM   #491
Erik D_lux's Avatar
Originally Posted by Shaunkjar View Post
So cool! What an amazing setup.
Thanks Shaun!
You should try and make it out to our comp on the 28th.
Yeah, comp scene is no bueno. Even if it was, people here refused to run a sportsman and try anything new.
Even though its the comp scene thats slow, I think I just like the opposite end of the spectrum when it comes to crawling. I would be more interested in a 1/3 scale super with 8 wheels.
Old 02-13-2015, 07:13 AM   #492
1/3 scale with 8 wheels! When are you starting the build thread? Hahahaha
Old 02-13-2015, 09:20 AM   #493
That's crazy, Vegas is the other way - We all built shaftys and not many really want to play with MOAs.
I love building regardless of what others do or want. But I can understand not wanting to put money into something that wont be used as much.
doublej is offline   Reply With Quote
Old 02-13-2015, 09:33 AM   #494
You know my address
Man I wish... All your goodies I bought for muh Squatch has squashed any hope I could have of buying this masterpiece from you.
Old 02-16-2015, 07:39 AM   #495
Erik D_lux's Avatar
Or... maybe I will go the other direction. I just like it to be as complicated as possible. Many, many channels that actually do something.
My standby idea of a 1.9 MRC with dig and rear steer is still a solid idea. I just need backing. Seriously though, how sick would that be?
Old 02-16-2015, 11:21 AM   #496
Yep, I'd buy in! XR mod F/R with some 4.25" rover's, maybe a stretched WB..
winnerone23 is offline   Reply With Quote
Old 02-16-2015, 12:00 PM   #497
It would pull some crazy lines I bet
hillbillyrc is offline   Reply With Quote
Old 02-17-2015, 06:36 AM   #498
Erik D_lux's Avatar
Ideally, my only rule would be 4.25" tall tires at the max. Do whatever you want with the wheelbase, track width, body, bodyless etc,.
Old 02-17-2015, 07:46 AM   #499
Some kind of wheel base and track width Max would have to be, wouldn't it? What would a gate width be regulated by or be?
Plans are rolling now.. Even if only for fun..
Old 02-17-2015, 07:53 AM   #500
Erik D_lux's Avatar
Why would you want to regulate the track width or wheelbase? I would just let technology and trial and error figure those out. If you wanted to build a car that has a 24" wheelbase on 4.25" tires, more power to you. I dont think it will be beneficial. Same for track width when your gates are 10" (?) wide. Everybody might start out different but would eventually end up close to the same. Then the cool part is when somebody comes up with a different idea than the rest and blows their ideas out of the water.
What I really like about supers and what I would really like to see in the hobby again is a personal twist on cars. It would be awesome to have a guy show up with a 7" wide, 12" wheelbase car and compete with a guy who is 9.5" wide and 18" wheelbase. May the best man and ideas win, innovation would rule.
Dlux Sportsman build - Similar Threads
Dlux Berg Build Erik D_lux EnRoute Berg 1696 05-22-2018 10:10 PM
DLUX super build Erik D_lux Superclass Crawlers 578 07-20-2016 09:13 AM
Dlux Wraith Build Erik D_lux Axial Wraith 95 09-03-2012 11:09 PM
Dlux mini build Erik D_lux Losi Mini-Rock Crawler 92 09-22-2011 05:28 PM
