02-02-2014, 02:36 PM | #401 |
| Re: Dlux Sportsman build
I was showing my local ultra 4 guys around here what a "real" ultra 4 car can do and I was whooping up on them and their Pro4's. I quickly found out that my car is not built for that kind of beating for long periods of time. In theory, I dont know why the shock balls didnt work but none the less, I went with the more standard way to mount the front shocks like everybody else is doing. Worst case, if I have the same problem, I can run a washer on the top of the rod ball and can fix it when I get off course. Either that or maybe I shouldn't run this car ultra 4 style? |
02-02-2014, 02:40 PM | #402 |
Last thing for today. This may be super simple but I am loving bent rod ends lately! They seem to solve every simple problem that I have been having and easily. If you have my front servo mount you dont necessarily have to bend your links. I found some bent rod ends that work perfect. I also have these for sale on my website if you dont want to buy a whole pack and just need a couple. Bent/offset ends. I took the bends out of my links (except for the rear ones to clear the driveshaft). Here is full extension Full compression. They barely hit and not enough to worry about. Perfect! |
02-02-2014, 03:05 PM | #403 |
Rock Crawler Join Date: Feb 2013 Location: york
The bent rod ends are awesome they made it super easy to make a simple drag link on my crawler instead of having to bend an offset in the actual rod itself.
02-02-2014, 03:55 PM | #404 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
Jesus Christ man. I lose track of this thread for a little bit and shit hits the fan. Incredible. Just incredible.
02-02-2014, 07:42 PM | #405 | |
RCC Addict Join Date: May 2013 Location: York, PA
| Re: Dlux Sportsman build Quote:
I love them too, but I'm tired of buying the $7 axial pack that comes with 2 and bunch of other junk that I just throw away. | |
02-02-2014, 07:46 PM | #406 | |
Atleast from what I found.. Erik? | |
02-03-2014, 07:37 AM | #407 | |||
I need to find a strong 4mm bent rod end. Are the ones youre using on the tie rod a Axial 3mm drilled out to use with 4mm or are they 4mm from the get go? Quote:
See Weiners post above yours. | |||
02-03-2014, 07:48 AM | #408 |
The bent rod ends are just standard 3mm rod ends Sent from my C811 4G using Tapatalk |
02-03-2014, 07:53 AM | #409 |
Really want a bad ass 4mm bent end......
02-03-2014, 09:44 AM | #410 |
02-03-2014, 09:55 AM | #411 |
Pebble Pounder Join Date: Dec 2013 Location: Keller
| Re: Dlux Sportsman build TowerHobbies.com | Traxxas Linkage Steering 1/10 Rally VXL Others... drilling them out as they are beefy Another... Losi 17 Deg Rod Ends, Pivots & Hardware: CCR Last edited by MAVERICKJK; 02-03-2014 at 10:08 AM. |
02-04-2014, 07:50 AM | #412 | |
| Re: Dlux Sportsman build If they are and you can figure it out, please let me know. Quote:
I had nothing but horrible luck with those Losi ends when I had a LCC. It was not uncommon to break 5 or so a day and they are not dirt cheap either. | |
02-04-2014, 08:07 AM | #413 |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
I had nothing but horrible luck with those Losi ends when I had a LCC. It was not uncommon to break 5 or so a day and they are not dirt cheap either.[/QUOTE] That's amazing! I have been doing weekly comps for 3 years and have never broke one! Jerry |
02-04-2014, 11:49 AM | #414 |
Yeah, heard that before. I would break one every single time there was a 3-4 foot drop. |
02-04-2014, 11:54 AM | #415 |
[/QUOTE]That's amazing! I have been doing weekly comps for 3 years and have never broke one! Jerry[/QUOTE] Until next week... Now that you said "never".. ;) |
02-07-2014, 01:22 AM | #416 |
| Re: Dlux Sportsman build |
02-17-2014, 09:10 AM | #417 |
I am not sure that anybody has problems breaking the AR60 housings on a sporty but thought I would post these here too just incase. At the least, they look good. Quote: |
02-17-2014, 10:01 AM | #418 |
That rear truss could be very beneficial for my set up. Any chance to get them without the last 2 holes so I can shorten it for my shortened axle. Sent from my C811 4G using Tapatalk |
02-18-2014, 08:11 PM | #419 |
Sorry, forgot to answer this. I would think if you just need one without the last two holes that you could just cut what I have and make it work? Thats probably what I would do for you. Changing the file and making a 1 off would take more time just just cutting. |
02-26-2014, 12:13 AM | #420 |
Rock Crawler Join Date: Feb 2012 Location: OC
Do you have any videos of this rig running a course? Or do you have a Youtube channel? Would like to see this rig in action, it is really sweet, haven't seen anything like this on here..... |
Dlux Sportsman build - Similar Threads | ||||
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
DLUX super build | Erik D_lux | Superclass Crawlers | 578 | 07-20-2016 09:13 AM |
Dlux Wraith Build | Erik D_lux | Axial Wraith | 95 | 09-03-2012 11:09 PM |
Dlux mini build | Erik D_lux | Losi Mini-Rock Crawler | 92 | 09-22-2011 05:28 PM |
