07-28-2014, 11:53 AM | #41 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time.
Progress pics. I'll talk about some of these later, I'm busy right now. My rear extended MIP driveshaft finally came in and now I can finish the links and progress! 4wd finally! 1/8th inch front lower links seemed like such a great idea with as short a link length as I'm running up there, but when I threaded the 6-32 link end into the traxxas link and watched the plastic deform I was less than enthused about its chances for survival. 5-40 is a better thread end for the plastic imo, but then you sacrafice the rod end strength... my 5-40 die is trash now anyway. Maybe the answer is to drill out the rod end just a fuzz. Ill see soon because ill be running 1/8" e erywhere except the rear lowers. The straight steering tie will be plenty strong at 1/8", but it's when you put anything more than just a very minor bend on the rod anywbere it becomes a flex issue. The rear wheel width is too narrow at 9.5ish...gotta put some wider hubs on, front is wide at 11.5ish. Gonna leave the front alone for now though. Wheelbase is now 1/4" too long after extending the front lowers to get a more level servo as rowdy and cl advised. Gonna cut some 4mm straight links shorter on the rear to compensate. Comp this weekend will let me test her out if I can shore it all up this week and have her ready. It steers like this with stock vanquish wraith arms and dlux shafts: I think that I will like it. It appears to have maybe 10* more steering than my stock bully2 setup. Last edited by Master Basher; 07-28-2014 at 02:53 PM. |
07-28-2014, 02:57 PM | #42 |
If I were building a front axle set like this again, I would not use the ribbed end on the beef tubes. I would use a smooth end and use different chubs. Im not happy with set positions for caster. I would like to dial in between what the ridges allow. One rib more is too much caster for my steering setup.
07-28-2014, 03:49 PM | #43 |
You can do that now. Mark the in between spline on ur axle housing (where you would want ur caster to be). Pull the screw's out of the tubes that attach it to ur housing and ur C's off. Rotate the tubes 90° and line them up with where you want ur caster to be, drill holes, and zip ur screw's back in. Bam! It's exactly how you want it... |
07-29-2014, 02:27 PM | #44 |
We got a roller.. The body off my old bully will do for now. Gotta have something for Saturday. |
07-29-2014, 07:25 PM | #45 | |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time. Quote:
07-30-2014, 05:29 PM | #46 | |
It might be fine though. | |
07-30-2014, 11:43 PM | #47 |
Real proud of these babies. They are gonna shore up my rear wheelbase and look good doing it: |
07-31-2014, 10:05 AM | #48 |
I like it. |
07-31-2014, 06:30 PM | #49 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
I really like the smooth slow bend of your rear lower links. How did you accomplish that?
07-31-2014, 09:52 PM | #50 | |
The threading of the rod ends came afterward, and was a little bit difficult to get right because of the slight bend radius, but it came out nicely. Pm me if u have a need. Last edited by Master Basher; 07-31-2014 at 11:48 PM. | |
07-31-2014, 10:00 PM | #51 |
Did you thread those with a 10/32?
07-31-2014, 11:43 PM | #52 |
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time. |
08-09-2014, 12:42 PM | #53 |
Progress Pics. shocks and springs lined out, new rear 4 link plate, curved upper rear links, slipper eliminator, 80/16 48p gearing (52/10 32p didn't fit Crawlife, not sure how you got it to work on yours), some crawler innov. foams. Been experimenting with link and pinion positions. Lots of variance. Tuning is going to be fun. |
08-09-2014, 12:58 PM | #54 |
56/10 gearing is what I'm goin to have to say Crawllife is running.. Maybe 56/11(this is what I'm running) .. Rear shocks look a little long? Rear sits high.. |
08-09-2014, 01:04 PM | #55 |
| Re: Reinventing my AX10...(again) Sucker Punch Chassis time. Right now I'm using xlong big bores in the rear and long in front.. I thought id want a little longer but I dont have any wheel time in to know.
08-09-2014, 01:11 PM | #56 |
Chassis was prolly designed around a 3.5" shock, I believe.. When I built one for Marzzz23, the scx in the rear got limited some and fronts more.. Shorter shocks equal lower cog.. Better side hilling and vertical climbs. digging the links! |
08-09-2014, 02:29 PM | #57 | |
THanks! Just swapped the rears out and I still have more underbelly clearance than both of my pro rigs and it brings the rear down a nice bit. Tried the wall climb at the house immediately after and it went further up at an angle without falling on its' lid! | |
08-12-2014, 04:13 PM | #58 |
My moonbuggy is all ready to run... notice I didn't say finished. A rig is never "finished". This will give me a good look at the mechanics and movements while I tune it out and make a body for it. So body requirements are 8" long by 3" wide and 3" tall now? It sure seems like most run a lot more body than that nowadays. Why is that? |
08-12-2014, 04:19 PM | #59 |
Whoever can guess what I see as the biggest mechanical weakness, I'll award an A+ to. It has one particular weakness that needs to be addressed. It ain't in the drivetrain. |
08-12-2014, 04:44 PM | #60 | |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
Mechanical weakness meaning a underperforming area or a physically weak point (as in it could break easily?) | |
Reinventing my AX10...(again) Sucker Punch Chassis time. - Similar Threads | ||||
Crawllife's 5D Sucker Punch | Crawllife | Axial AX-10 Scorpion | 175 | 04-16-2015 11:43 AM |
Rottenbellys sucker punch. | rottenbelly | Axial AX-10 Scorpion | 14 | 03-09-2014 05:22 PM |
