09-24-2007, 03:26 PM | #201 | ||
Thanks Josh! They work really well too I was so pleased with them yesterday Quote:
All 4 are the fronts. I had already used the rears on my blazer. However the rears would probably work better with the X Trail | ||
09-25-2007, 08:41 AM | #202 |
Do we have any word on the release date of the production chassis?
09-25-2007, 08:51 AM | #203 |
The Wheels Keep Turning Join Date: Jan 2004 Location: Phoenix, Arizona
2-3 weeks. They are in production now and then will be anodized black.
09-25-2007, 07:20 PM | #204 |
Thats right guys, only a couple weeks until the final versions are ready to go. Hope you all have your builds in mind they will be here before you know it.
09-25-2007, 07:32 PM | #205 |
Quarry Creeper Join Date: Jun 2007 Location: arkansas
Sweet sounds good |
09-26-2007, 03:52 PM | #206 |
Pebble Pounder Join Date: Aug 2007 Location: South Central Mississippi
09-26-2007, 05:38 PM | #207 |
Rock Crawler Join Date: Aug 2006 Location: nc
ya dont you think that the testers should acualy test them and find problems befor acual production starts. just my 2 cents
09-26-2007, 05:55 PM | #208 |
09-26-2007, 05:58 PM | #209 |
were there any changes made. mine hasnt goten here yet so i dont know how good they work and what changes were made if any
09-27-2007, 09:20 AM | #210 |
| The "prototype testers" where the 3rd or 4th revision of the design, so we had worked out almost all of the bugs already. The production version has a few holes removed up front and the line of holes in the rear moved inwards some to get them away from the edge. Other then that they are the same. As with all products, we will continue to change the chassis if new ideas come up and as customers make suggestions.
10-01-2007, 05:56 PM | #211 |
Newbie Join Date: Sep 2007 Location: forked river
can you guys take preorders?
10-01-2007, 06:21 PM | #212 |
i got my prototype (short one) and i must say it looks good. now to find the time to finish building
10-02-2007, 02:23 PM | #213 |
10-02-2007, 02:25 PM | #214 |
Just realized I forgot to share the final product! Well at least running... Check it out TCS X Trail prototype Scale Frame Build: War Pig style |
10-03-2007, 01:12 PM | #215 |
Hey guys, more proto tester X-trails are in stock here: http://www.tcscrawlers.com/home.php?cat=269 |
10-03-2007, 03:07 PM | #216 |
Newbie Join Date: Sep 2007 Location: Indonesia
are those prototype strong enough for crawling? or should i wait for the final release? i really want to get one.
10-03-2007, 03:16 PM | #217 |
| Mine is holding up really well so far. The chassis has some flex in it but alittle bracing goes a long ways. Of course the aluminum version will be superior
10-03-2007, 03:52 PM | #218 |
which one is yours? long/short?
10-03-2007, 03:59 PM | #219 |
10-07-2007, 05:33 PM | #220 |
Quarry Creeper Join Date: Sep 2005 Location: VARCOR
| 2.2 TCS X-Trail Prototype
OK, I finally got some run time on my X-Trail long. I first built it with full droop but didn't like the way the rear axle wrapped under the truck. I then tried many different options. I ended up running 90mm shocks on the rear (Jato shocks) and axial shocks drooped on the front. I'am amazed at how well this setup works. I first wanted to try and build this stock out of the box and change things as I go. I would highly recommend other tires as the stock axail tires stink. I going to order Losi rock claws as soon as the are available again. I added weight too each tire 7oz front and 3oz rear. The axial is so light I think it might just need a little more weight. It was awesome with the spring rear and droop front. Heres a few pic for now.
