Thread: New links for my axial
Old 12-12-2007, 02:43 PM   #21
show some pics if you can. I'ed like to see your setup. I also have made my own. I used 1/4 round 6061 aluminum.
The Gooch
El Gooch is offline   Reply With Quote
Old 12-13-2007, 07:50 AM   #22
Originally Posted by JUSTGOINGSLOW View Post
Hay Rockcrawler what is the degree of angle right now and how far up do you have the bend
I bent mine to 30 deg 1.5 inches from one end . Used a swage lock tubing bender that made a 3/4 in radius. Works slick after several test runs I have almost no scraches on the bottom.
Cave Dave is offline   Reply With Quote
Old 12-13-2007, 08:43 AM   #23
Thanks I'll give it a shot
JUSTGOINGSLOW is offline   Reply With Quote
Old 12-13-2007, 09:55 AM   #24
Originally Posted by Rockcrawler View Post
125mm or 4.92 inches Center to center.
I cut the rod 4 inches then bent it. Finally measured center to center with rod ends = 4.970
Old 12-14-2007, 11:41 PM   #25
Anyone know how to bend delrin links?
mauromj is offline   Reply With Quote
Old 12-15-2007, 10:58 PM   #26
You have to heat them. I dont know how though.
Rockcrawler is offline   Reply With Quote
Old 12-28-2007, 03:20 PM   #27
New links with 6/32 allthread.
