12-17-2012, 08:22 PM | #1 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
| Crawler Innovations may have a rear driveshaft fix for the AR60 sporties! C.I. 4340 steel; 5mm - Axial Transmission Outputs The long output, originally intended for the front output looks like it will go to the rear of the truck, while leaving the gearbox forward in the chassis. This will depend on your truck, but may change the rear shaft's angle enough to keep it from hitting the rear links! No more flipping of the rear axle! |
12-17-2012, 08:30 PM | #2 |
| Re: Crawler Innovations may have a rear driveshaft fix for the AR60 sporties! My rear shaft is close and only has a little clearance, but I could increase the clearance from my lower left link, if the output shaft were longer. I have not tried it personally, but it would just HAVE to work! |
12-18-2012, 05:58 AM | #3 | |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: Crawler Innovations may have a rear driveshaft fix for the AR60 sporties! Quote:
I did this to my Wraith build "PHANTASMAGORIA" by DRV KRAWLER . This allowed me to use a standard Axial AX10/SCX10 Transmission without a dig. My wraith has taken a back burner while I build my 4 year old a scaler. Also my new 1:1 is taking any and all extra cash. Last edited by DRV KRAWLER; 12-18-2012 at 06:01 AM. Reason: added pictures | |
12-18-2012, 04:48 PM | #4 |
Yup, that's the idea. It should get the shaft further away from the rear links.
12-24-2012, 11:23 AM | #5 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
it's a cool product for sure, just a little on the pricey side IMO
12-24-2012, 11:38 AM | #6 |
Pay the price, or run a goofy diff setup?
12-24-2012, 08:13 PM | #7 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
Worth every penny. I've been running a set of his original run of 4340 outputs with maxx shafts and they don't even look worn. These will take whatever abuse you throw at them.
Crawler Innovations may have a rear driveshaft fix for the AR60 sporties! - Similar Threads | ||||
Stock Losi Driveshaft Pin Fix | Crawl_Before_Walking | Losi Mini-Rock Crawler | 4 | 04-08-2010 05:11 PM |
New here, driveshaft CV problem, quick fix?? | theothertoymaker | Team Losi Comp Crawler | 1 | 08-10-2009 01:54 AM |
Stock Driveshaft fix | Positronic | Axial AX-10 Scorpion | 8 | 01-28-2009 07:35 PM |
Axial's new driveshaft ring (fix) | moonweed | Axial AX-10 Scorpion | 30 | 01-05-2008 08:31 PM |
