04-10-2015, 07:37 PM | #1 |
Rock Stacker Join Date: Mar 2015 Location: west virginia
| New motor. Change gearing?
I'm getting a new motor for my ax10. It's a Holmes Hobbies CrawlerMaster expert 13T Will I need to change my stock gearing? Thanks Thomas |
04-11-2015, 06:44 AM | #2 |
| Re: New motor. Change gearing?
Depending on your intended usage and input voltage, it would be a good idea to lower your gearing. If your only trailing on 2s, then you could almost get by on the stock gearing. If you have any plans of rock crawling, or running 3s, then you really should gear down to something between 15/87, and 17/80 depending on conditions and how heavy your throttle finger is. Note that pinions smaller than 17 teeth won't reach the stock 80 tooth spur, you'll have to pickup an 87 tooth spur. |
04-11-2015, 12:34 PM | #3 |
Thank you
04-29-2015, 08:49 AM | #4 |
Newbie Join Date: Nov 2014 Location: Kemah
Im running Homes hobbies 45t tq Master and I believe a 60 spur and 13 tooth pinion. Seriously amazing set up for crawling! oh and 32 pitch of course. The pinion is actually from traxxus (weird i know but it fits perfect)
New motor. Change gearing? - Similar Threads | ||||
Is a motor change worth it? | tastetickles | Axial Yeti | 17 | 02-12-2015 02:49 PM |
20t motor and 45t motor gearing question? | rcstrike | Newbie General | 1 | 11-16-2011 03:40 PM |
esc and motor change up.. | Finnigan182 | Axial SCX-10 | 2 | 04-03-2011 08:29 PM |
change of motor or pinion on bully? | dynamaxxed | Newbie General | 3 | 02-07-2011 06:38 AM |
Should I change or upgrade my motor/esc? | acrosteve | Electronics | 13 | 08-06-2009 07:59 AM |
