05-18-2015, 10:49 PM | #1 |
Newbie Join Date: Apr 2015 Location: IE
| So uh anyway to slow this thing down? AX10 DB RTR
I bought an AX10 Deadbolt RTR and put a venom 5400mah 2S 20C in it. The speed and throttle control is fine for me but its going to be to much if I want to let my kids learn and play with it. They are 3 and 6. Is there anyway to limit the throttle on it, because I sure would like to let them play and not destroy it. Sent from my iPhone using Tapatalk |
05-18-2015, 10:55 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Program the throttle curve with a castle link if your running the ae2 esc. Or drop your pinion size down a few teeth
05-19-2015, 05:12 AM | #3 |
Newbie Join Date: Apr 2015 Location: north east nevada.
| Re: So uh anyway to slow this thing down? AX10 DB RTR
They come with a 20 turn motor stock. Can replace with a higher turn motor. Like a 35 turn or even a 55 turn.
05-19-2015, 08:17 AM | #4 |
| Re: So uh anyway to slow this thing down? AX10 DB RTR |
05-19-2015, 08:22 AM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: here
Castle Creation castle link allows you to program castle creation ESC .
05-19-2015, 09:30 AM | #6 |
05-19-2015, 03:16 PM | #7 |
Rock Stacker Join Date: Jan 2014 Location: Hamilton, Ontario, Canada
Buy a new radio with Throttle end points. Then turn the end points down. That will limit the trigger to 0-100% So say you turn it down half way. then the squeezing the trigger all the way will give you %50 throttle. Tuen it down more you get 25% ect ect. That would be the easiest way to go from fast to slow without taking it all apart. |
05-19-2015, 06:59 PM | #8 | |
| Re: So uh anyway to slow this thing down? AX10 DB RTR Quote:
Also sounds like the most expensive. I picked up a 35T motor, I'll start there and then re gear if needed. I will keep the different TX in mind for future builds though. Sent from my iPhone using Tapatalk | |
05-20-2015, 10:47 AM | #9 |
Change the motor, problem solved
05-22-2015, 09:26 AM | #10 |
Rock Stacker Join Date: May 2014 Location: Germany
Hi, I am running a 35turn Novak Terra Claw and its ALOT slower, but the torque is great!!! |
05-24-2015, 03:28 PM | #11 |
Added the same motor. Novak 35t. Excellent speed for crawling and my kids. I'm happy! Sent from my iPhone using Tapatalk |
05-27-2015, 06:21 PM | #12 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
Don't replace the motor unless gearing-down isn't good enough. Gearing-down converts the motor's power into torque, which is useful when crawling, whereas a higher-turn motor has higher electrical resistance, thus lower power throughput, thus it's a weaker motor overall -- which *isn't* useful when crawling. The sole exception is if you keep cooking lower-turn motors even with the lowest gearing you can get -- then you really do need a higher-turn motor.
So uh anyway to slow this thing down? AX10 DB RTR - Similar Threads | ||||
Axial ax10 way too slow | Jophuss36 | Axial AX-10 Scorpion | 8 | 07-08-2011 01:48 PM |
Axial AX10 slow radio response | vikingship | Axial AX-10 Scorpion | 2 | 01-04-2010 06:16 PM |
What motor or pinion for RTR to slow it down | voltaire21 | Axial AX-10 Scorpion | 9 | 03-17-2009 10:13 AM |
