01-03-2016, 10:06 AM | #21 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
| Re: Wheelbase vs trailing arm length
Installed some Blue Monkey Wraith length trailing arms and it made the wheelbase 14.25". I kinda want to go shorter still so might try to pickup some twin hammers trailing arms. |
01-03-2016, 10:34 AM | #22 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
| Re: Wheelbase vs trailing arm length That looks good! What rear uppers? Wraith? Mind putting the spare tire back on and taking more pics?
01-03-2016, 11:39 AM | #23 |
wraith uppers were too short, I think because the bomber has the lowers less triangulated it pushes the wheelbase back a bit more that the same setup on a wraith skid. I made these for now with revo ends and all-thread, when I finalize my setup I'll sleeve them with tubing. I'll try to take a pic with the spare here later. I prefer it without the spare and with it off the rear end looks way to far back, hence why shortening it and cause less belly-outs on ledges.
01-03-2016, 12:17 PM | #24 |
14.25" wheelbase with spare: |
01-03-2016, 12:21 PM | #25 |
Yeah it does hang out there pretty far but 1:1 Bombers are similar |
01-03-2016, 12:22 PM | #26 |
| Re: Wheelbase vs trailing arm length |
01-03-2016, 12:43 PM | #27 |
The 1:1 does but some but the axial has the rear chassis right above the axle which is ok when hidden by spare but w/o spare I dont care for it. Also shorter wheelbase will allow for rear steer easier to clear servo inside chassis, just have to gut the bottom of the fuel cell
01-04-2016, 10:39 AM | #28 | |
| Re: Wheelbase vs trailing arm length Quote:
01-04-2016, 10:41 AM | #29 |
Looks like this thread has stirred up some good interest on the Wraith length trailing arms on a Bomber. Good enough that we are all sold out of not only the Bomber length but also the Wraith length! Thanks a bunch for the orders and support guys! We should have more of both sizes in about 2 weeks. |
01-04-2016, 11:29 AM | #30 |
| Re: Wheelbase vs trailing arm length The Wraith skid was changed to a stock RR10 thanks to Screamer posting where I could get one with DMG adapter. I thought the UCfab skid was a one off thing to be honest so I overlooked it. Maybe later if.it.bolts up I'll get one. Thanks for the heads up though.
01-04-2016, 02:04 PM | #31 | |
01-04-2016, 02:48 PM | #32 |
x2 I'd love a third length option in Dlux's awesome 7075!
01-05-2016, 07:14 AM | #33 | |
I can do whatever length you want, cheap too as long as I can throw them in a batch and they are not 1 off. On top of that, if you want a upper link to match, thats not a problem. No using janky Jato ends either, straight up Revo and proper. | |
01-05-2016, 08:36 AM | #34 |
Awesome. I'd definitely be interested in the twin hammers length trailing arm and matching upper for the bomber. From what I can tell the uppers need to be pretty much the same length and the trailing arms eye to eye? Sent from my SM-G920V using Tapatalk |
01-05-2016, 08:28 PM | #35 | |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
Can you confirm? Thanks! | |
01-05-2016, 09:01 PM | #36 |
It may be that he is running the currie rear axle and not sure if there is a truss difference in link mounting location. My current trailing arms are some used Blue Monkey wraith ones and when I used wraith length uppers with those it pointed the pinion down a bit. When comparing the stock bomber uppers/trailing arms they are pretty similar in length. I bet DLux could confirm when length upper is required with a Twin Hammers length trailing arm.
01-05-2016, 09:15 PM | #37 |
Rock Stacker Join Date: Jul 2015 Location: California
Can anyone tell me how long the front lower and upper links are? I would appreciate it mucho!
01-05-2016, 09:35 PM | #38 | |
01-05-2016, 09:40 PM | #39 |
01-05-2016, 10:29 PM | #40 |
I am running a Currie off center axle in the rear now but ran it before with a stock AR60 housing. On the Currie axle, do to its design, the lower link mounts can only be ran in the flipped position or with the longer link mount at the bottom where the TA attaches. On the AR60 housing I ran the link mounts in the standard orientation with the shorter mounting point at the bottom. This difference alone will give you a 5mm effective link length difference. Not sure where the Currie truss is in relation to the stock truss on the stock axle. This is one area where trailing arms are inferior to conventional lower links that have much more adjustment possible. It always gets me how dynamic suspension setup is.
Wheelbase vs trailing arm length - Similar Threads | ||||
Anyone done a trailing arm rear suspension? | 95geo | Axial Wraith | 26 | 09-03-2013 11:07 PM |
Twin hammers trailing arm length? | fordsuperduty | Vaterra Twin Hammers | 0 | 06-03-2013 03:57 PM |
Shortcourse 4-link vs. trailing arm | desertmaxx | Non Crawler RC's | 4 | 09-07-2010 06:40 PM |
trailing arm links | mookie | Redcat Crawlers | 6 | 07-07-2010 06:43 PM |
