06-06-2016, 09:24 PM | #141 | |
Quarry Creeper Join Date: Jan 2007 Location: Isanti, MN
| Re: Wheelbase vs trailing arm length Quote:
I am debating on going back to stock length or wraith length. I have incision rear stock length uppera sitting around from my kit. Sent from my SM-G900V using Tapatalk | |
06-10-2016, 05:08 PM | #142 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
I know its been said that I might regret not going to the shorter TH arms right off the bat; but, I'm leaning towards just dropping down the 1/2" to Wraith length wheelbase. 1) What are the options for Wraith length trailing arms? Apparently UCFab is done making them? ...and Dlux is out. Is Blue Monkey the only other option? 2) It was briefly mentioned back a few posts that someone could have kept their Twin Hammers length TA's and just added longer rod ends to get Wraith length. Would this be a realistic option allowing the ability to change to either? ...or would this leave you with an inferior product compared to the correct length TA's from the start? 3) If I go to Wraith length TA's, will I still be able to run my VP Antiroc swaybar in the standard position (forward frame mount not back of frame)? For fit, I have the AR60 axles with Beef Tubes and don't plan to go to Currie or SSD axles at this time. |
06-10-2016, 05:21 PM | #143 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
Scroll up. JEC makes stainless steel wraith length TAs.
06-11-2016, 10:25 AM | #144 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
2. Yes its totally fine, but if you use a longer rod end, I would use RPM rod ends. Reason I got the wraith length is so I can run it with 2 revo ends and have wraith length or I'll try using one long RPM rod end to get yeti length. 3. Yes. | |
06-11-2016, 02:48 PM | #145 |
Just got the JEC trailing arms in the mail today. Wow. They are a piece of art.
06-11-2016, 03:53 PM | #146 |
I just got my third set from JEC, love 'em. I use DLux arms when I'm trying to save weight and JEC when I want more weight in the rear. Blue Monkey arms would also be a great weight saving option and they are made with 7075 also.
06-13-2016, 12:09 AM | #147 |
Blue Monkey Wraith TA's ordered. Now I just need uppers. Hoping to find Incision SS uppers... even if I have to order the whole set just for the upper links. Maybe I'll throw the Bomber uppers I have in the kit and re-sell as a bomber SS kit since the rest is the same.
06-15-2016, 03:41 PM | #148 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
Just ordered some Wraith TAs from JEC. These will be replacing the stock Twin Hammers TAs I have no my rig now. I like the way the rig handles with the TH TAs crawling, but it gets cray cray when I get hard on the throttle (I know it's a Bomber). I'm hoping the Wraith TAs will give me the best of both worlds. I'll post some pics as soon as I get them installed. BTW, JEC is very cool and very helpful. So is Dlux, Holmes Hobbies, CI. We have some kick ass vendors in this part of the RC world. |
06-17-2016, 01:45 PM | #149 |
I'll investigate once I get all the pieces together; but, does shortening the TA's affect the spring rate? It seems that moving the wheel/axle line closer (1/2") in the case of Wraith TA's would affect the fulcrum point and stiffen up the spring since their is now less leverage. I wrote that wrong as the spring wouldn't actually get more stiff. Would the resting height and feel of the spring change? Is this the case from anyone's experience? Or is any difference (if technically even there) too small to notice? Or am I missing an obvious physics key that disproves my thinking? Last edited by powder4breakfast; 06-17-2016 at 01:48 PM. |
06-17-2016, 02:21 PM | #150 | |
06-17-2016, 03:11 PM | #151 | |
I was curious as to whether I should go ahead and make the changes at the same time I install the new links and TA's, or try it out first if there is a difference that can be felt. | |
06-17-2016, 05:49 PM | #152 |
That is a good question. But spring rate is spring rate, it doesn't change unless your running progressive springs. But the difference is leverage, TA's just make it compress easier vs shocks on axle. Thats why the bomber has a lot of torque twist vs say a wraith with links and shocks mounted on axle. Moving the shock back on the TA helps with torque twist. Im sure someone will get all scientific with it but thats the simple verison. Lol. Edit: also, people think adding more preload turning the shock collars down adjusts spring rate, which is not true. Last edited by 84yoda; 06-17-2016 at 05:52 PM. |
07-17-2016, 01:05 PM | #153 |
Newbie Join Date: Aug 2010 Location: boston
Read through the posts here, tried a combination of few things, but not sure I got this right. Currently using JEC wraith-length trailing arms with BMRC wraith-length uppers. Stock rear axle. Shortened drive shaft length from the included RTR parts tree. I'm not sure I have full suspension travel with this set up - there isn't any binding but it seems upper travel is limited when compared to the front. Is there anything I'm missing? |
07-17-2016, 01:49 PM | #154 |
Shortening the TA will make the springs feel like they are stiffer. Increase the length and they will feel softer.
07-29-2016, 11:34 AM | #155 |
Rock Crawler Join Date: Mar 2016 Location: HB
From what I've read, it looks like everyone is using the stock driveshaft with the shorter pieces from the parts bag. Are any of you running MIP shafts with the shorter TA's? I'm leaning towards the wraith length TA but not sure about what shaft to buy. Would I just buy the wraith Mip kit and it'll pop right in? Do I need to buy the bomber Mip kit from super shafty and try to modify it? After looking @ the wraith Mip shafts online I noticed they have 2 of the longer end pieces instead of 1 like my scx has. Any ideas, experience, or suggestions?
07-29-2016, 11:47 AM | #156 | |
Rock Stacker Join Date: Dec 2004 Location: Parker, CO
07-29-2016, 11:54 AM | #157 | |
07-29-2016, 12:05 PM | #158 |
Thanks screamer. Runnin mamba monster X with Holmes pp 2700kv and figured it's only a matter of time til the rear lets go. My yeti spun the rear into pieces on its 4th run out. Hate when a rig is down for something like that. Good to know yours is holding up on 4S, I'm only runnin 3S on mine @ the moment.
07-29-2016, 12:25 PM | #159 |
I'm running an MMX with a Holmes Puller Pro 3500kv on 3s and 4s and I'm running an MMP with a Holmes 2200kv on 4s. No driveline issues yet and my driveshafts are definitely my weakest point being the only plastic part in the entire driveline. SuperShafty bombproof trans on the 3500kv combo and RRP upgraded Bomber trans on the 2200kv rig. Not a single driveshaft issue yet. I will add that I don't do a lot of bashing type driving but I do like to go full tilt now and then. Most of my driving is technical crawling or rock bouncing. There are a couple other variables to consider. On my go fast rig I run 30% punch control and both trucks have RRP slippers.
07-29-2016, 12:41 PM | #160 |
Good stuff. I like to get to the spot fast and crawl em slow too, no bashing. Have my 10+lb expensively upgraded yeti to beat the snot out of.lol I'll rock the stock driveline til I have a problem. You just opened my budget to buy something else for my rig!! Thanks
Wheelbase vs trailing arm length - Similar Threads | ||||
Anyone done a trailing arm rear suspension? | 95geo | Axial Wraith | 26 | 09-03-2013 11:07 PM |
Twin hammers trailing arm length? | fordsuperduty | Vaterra Twin Hammers | 0 | 06-03-2013 03:57 PM |
Shortcourse 4-link vs. trailing arm | desertmaxx | Non Crawler RC's | 4 | 09-07-2010 06:40 PM |
trailing arm links | mookie | Redcat Crawlers | 6 | 07-07-2010 06:43 PM |
