04-18-2016, 04:37 PM | #1 |
Newbie Join Date: Mar 2016 Location: sol cal Desert
| Shorter bomber wheelbase (Drive Line Length)
Hello, I'am in need of help on my bomber build I have shortened my wheelbase by using Twin Hammer trailing arm's and need help on the Drive shaft proper length so I may get the full upward travel of my suspension. The drive shaft that I now have is a Yeti MIP and it bottoms out and bind's and will not allow for full compression upward travel. My Shocks are King's with the front shock on the trailing arm 110mm and the rear 120mm.I'm new to the crawling arena and sure could use any help in the area of the Direction and of drive line to use . Thank You, Steve |
04-18-2016, 04:44 PM | #2 |
| Re: Shorter bomber wheelbase (Drive Line Length)
Use a saw and cut. Or a dremel. Or a file.
04-18-2016, 11:30 PM | #3 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
I run the TH TAs and use the short spare drive shaft that is on the accessory tree included with the Bomber. Same length as the front I think. I haven't gotten all scientific and measured. If you're going try and use the MIP, you'll be hacking a lot off of it. EeePee forgot to include "sweat and tears". |
Shorter bomber wheelbase (Drive Line Length) - Similar Threads | ||||
Going for shorter wheelbase | Tech | Axial Wraith | 2 | 12-26-2015 08:42 AM |
Shorter or longer wheelbase | Measuredpath | Tamiya CR-01 | 4 | 10-14-2014 06:30 PM |
Shorter MIP drive lines? | mmbackpacker | Axial SCX-10 | 5 | 05-08-2013 09:51 AM |
shorter wheelbase | bahogtubig | Redcat Crawlers | 3 | 12-14-2010 06:58 PM |
Rear link length for shorter wheel base | Expat Crawler | Axial SCX-10 | 4 | 11-10-2009 01:53 PM |
