Thread: Wroncho build Problems
Old 10-14-2012, 12:23 AM   #1
Default Wroncho build Problems
Okay I have just go a scx10 chassis kit and I bought a wraith rtr and I have custom links and mip shaft my problem is drive shaft angles I can't get them to connect to the out puts is it because of the wraith tranny case
RcBashertruck is offline   Reply With Quote
Old 10-14-2012, 04:38 AM   #2
I believe the pinion angles are pretty rough. I was having a hard time just using my RidgeCrest trans.
Sent from my Samsung Galaxy Note (Phablet)
AsILayDying is offline   Reply With Quote
Old 10-14-2012, 10:35 AM   #3
Default Re: Wroncho build Problems
So what can I do to make it work I made links for my wraith and they are great but it seems like my mip shaft is to long in the front
Old 10-14-2012, 11:59 AM   #4
zonkerd's Avatar
what i did was flip the diffs so they are lined up with the trans outputs, ran 4 link and made sure the top links were equal lenths(no dog tracking) this truck has been in number of g6 scale runs and i also just added vp dig to it. last i posted this up i got bashed because to some peeps this wasnt right. hey as long as it works. this is one mean truck here is a pic.sorry so big
zonkerd is offline   Reply With Quote
Old 10-14-2012, 12:00 PM   #5
zonkerd's Avatar
Old 10-14-2012, 12:05 PM   #6
zonkerd's Avatar
the upper link mounts made them span the whole chassis lenth(no flexing under load) and im running vp ti links for the wraith uppers and lowers.
Old 10-14-2012, 12:19 PM   #7
I have done what u have done is change the the sckid plate where the spur is facing the front axle but it seems like my mip shaft is too long
Old 10-14-2012, 12:23 PM   #8
zonkerd's Avatar
first you have to get the diffs lined up (flip the housings front to back) so you are only working with 1 angle. do you have pics?
Old 10-14-2012, 04:43 PM   #9
So what u mean axle diff be on the same side though right
Old 10-14-2012, 06:34 PM   #10
zonkerd's Avatar
diffs need to in line with trans outputslook at the pics i have up
Old 10-14-2012, 11:14 PM   #11
Okay I did that but my MIPS bind as if they are to long I posted a video it's on my YouTube channel which is the same as my user name
Old 10-14-2012, 11:45 PM   #12
zonkerd's Avatar
how are the angles? also did you greese the cups?I am running wraith shafts in my rig, ive had binding issues with mips.
Old 10-15-2012, 06:03 PM   #13
I got it I think I may have to cut the rear drive shaft or just go to a scx10 tranny case front drive shaft looks great as if it was in my wraith I will post a link I will make a video
Old 10-15-2012, 07:20 PM   #14
So I got it done if u want to see what I did email me at nathorp4@Gmail.com it works now just Need steering
Old 10-15-2012, 07:47 PM   #15
Why not just run a 3 link with a pan hard set up? This will make the suspension all around work better, plus will reduce the amount of bump steer in the front.
BLKXJ 96 is offline   Reply With Quote
Old 10-15-2012, 08:02 PM   #16
Why not post your solution?
I'm looking to convert my wraith to a scx10 frame here in the next couple weeks. Seems some people are mounting the links to the outside of the frame.. what did you end up doing?
Seems like this may be my best bet.
Anyone ever run jeep-style radius arms?
monkeymagic9 is offline   Reply With Quote
Old 10-15-2012, 08:32 PM   #17
I built this rig with a 3 link and VP pan hard set up, it crawls perfect.....almost like a sportsman rig.
Old 10-15-2012, 09:05 PM   #18
Video will be up of my set up when I get my phone charged cuz my camera does not have the 1080p my phone has
Old 10-15-2012, 09:48 PM   #19
Here is the video for u monkey magic
YouTube - Wroncho Set Up
Old 10-16-2012, 08:12 AM   #20
cool, so basically the same idea as zonkered's.
lol you like saying my name.
Wroncho build Problems - Similar Threads
CMaD's Wroncho build. CMaD Axial SCX-10 25 02-01-2014 11:16 AM
West coast disrtuctions wroncho build wcdfmt510 Axial SCX-10 15 01-26-2012 11:00 PM
TTC-ish Scale-ish Budget-ish Wroncho-ish Build Meatwad Axial SCX-10 77 01-19-2012 03:00 PM
Build problems! Apie Tamiya CR-01 4 09-26-2009 08:41 PM
problems during build-up. silverbullet Tamiya Clod Buster 11 03-10-2006 07:14 AM
