06-11-2011, 11:02 PM | #21 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
Back to the grease topic for a minute-I discovered all that grease doesn't do much good unless you plug up the little holes on top of the axles, where the 4 link bracked mounts. After running around in sandy mud around here my rear axle was clean inside (4link mount installed) and my front was full of sand!
06-12-2011, 05:57 AM | #22 | |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Wes Last edited by brazwewn; 06-12-2011 at 07:21 AM. | |
06-12-2011, 07:09 PM | #23 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
took it out today, forgot cammera though i striped the stock servoarm, put a new one on, and 10mins later broke the driveshaft at the pin |
06-12-2011, 07:15 PM | #24 |
i also have a q about overdrive and under drive, do i put over drive in the front axle with stronger gears in the back, do i put overdrive in front and under drive in rear, or upgraded gears in front, and underdrive in rear. so wich way is better and why, im going to be running a 30-35t motor or a 10t puller on 3s. |
06-12-2011, 08:51 PM | #25 |
ok so just to make sure if i go with the 1ot puller on 3s, what will most likely go first? I will have mip shafts. just want to order the stuff that will go first, also does this(link below) replace the stock slipper cluch? and is it good to put this in or just put other upgrade stuff for the slipper? http://www.rpphobby.com/product_p/rrp1542.htm if this is not good what stuff sould be upgraded for the slipper? |
06-13-2011, 08:36 PM | #26 |
well still cant find my camera but heres where i want to go with it, i want to make it a mud/ trail truck. It will look sort of like this: not mine, but thought it looks cool, and one of my dads friends has something like it. ill use a clod body, hh 10t puller on 3s, boggers in back, irocks upfront. hopefully cut the hood and put hinges to hide the electronics and battery. |
06-15-2011, 10:22 PM | #27 |
any body know where to get a front grill parts tree for a clod body? Rpp has them but not in stock.
06-17-2011, 03:59 PM | #28 | |
i want to make this thing as close to indistructible as possible. | |
06-17-2011, 04:47 PM | #29 |
Rock Stacker Join Date: Apr 2011 Location: Bloomington
| Being a fellow Minnesotan, go to rccarkings.net. They have a store near my house in Eden Prairie. I go there often and know they stock Clod bodies and parts. Check it out and give them a call. I'm sure they can help.
06-17-2011, 04:50 PM | #30 | |
heres some picks finally and a carnage pic | |
06-17-2011, 06:56 PM | #31 | |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
robinson racing parts # 1541 and 1542 will sufficiently beef up the tranny. The third gear is already metal so you wont need it. | |
06-17-2011, 06:59 PM | #32 |
06-17-2011, 08:42 PM | #33 |
ok so are the beef tubes nesisary? so heres what i plan on upgradeing from list above. axle gears trany gears axle diffs?(are these good in the kit?) hardend outdrives for the tranny aluminum axle lockouts cvds(If they help, do they?) im trying to make sure i dont break anything with the 10t puller on 3s so if there is any other things that will help bomb proff this thing, please say and if you can give a link. |
06-17-2011, 09:03 PM | #34 |
Tranny: http://www3.towerhobbies.com/cgi-bin...?&I=LXWTN3&P=7 http://www3.towerhobbies.com/cgi-bin...&I=LXXBK3&P=ML This is the tranny 1 piece gear and outdrives http://www.vanquishproducts.com/vanq...n-housi10.html Not necessary but aluminum over plastic Trans to axle: http://www3.towerhobbies.com/cgi-bin...?&I=LXAWJY&P=7 or Junfac order to custom length Front axle: http://www3.towerhobbies.com/cgi-bin...?&I=LXVDE7&P=7 Beef Tubes FELSENFEST AX10 spools (locker) http://www.rccrawler.com/forum/showthread.php?t=164999 I wouldn't do axles gears till they break IF they do Rear Axle: beef tubes RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits http://www3.towerhobbies.com/cgi-bin...?&P=9&I=LXUFG6 You dont have to get these from tower hobbies i just used them for link purposes and you can get part numbers from them Other things to consider...Shocks, servo winch, WATERPROOFING, ditch the stock tires get some ROk LOX http://store.rc4wd.com/Rok-Lox-19-Comp-Tires_p_696.html Last edited by Wasp26Jim; 06-17-2011 at 09:17 PM. |
06-17-2011, 09:19 PM | #35 | |
http://www.rpphobby.com/product_p/ax30544.htm this and http://www.rpphobby.com/product_p/rrp1540.htm this right? | |
06-17-2011, 09:21 PM | #36 | |
06-17-2011, 09:25 PM | #37 |
And you need a "MUDBUTT" sticker |
06-17-2011, 09:26 PM | #38 | |
and for the front will this work with the hadbros kit? http://www.rpphobby.com/product_p/sktruss1.htm or the tallerone, if the work if not then what? | |
06-17-2011, 09:30 PM | #39 |
I wanna be Dave Join Date: Aug 2007 Location: *
06-17-2011, 09:39 PM | #40 | |
Roger that dont worrt about four linking the front, just use what comes with the handbros kit. I just did it today and it is slick. this is what i used on the rear DmG's/Truss/Link Mount cause i like my link ends vertical not horizontal | |
