06-07-2011, 05:49 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
| Minnesotamudders honcho kit
so i finally got my kit in today not going to bore you with pics until its painted, but i have a few questions, when im building the axles can i pack them full of marine grade grease or do what the directions said? |
06-07-2011, 06:03 PM | #2 |
Pebble Pounder Join Date: May 2010 Location: Ringgold GA USA
I didnt buy a kit i got the rtr but i vote pack them sumbitches full. you will be glad you did when you pullum apart to clean um.
06-07-2011, 07:03 PM | #3 |
you can if you run in lots of water, and it would protect them well, i didnt because i dont run in lots of water and its a mess.
06-07-2011, 07:17 PM | #4 |
well i packed them full never know what im going to find(DEEP MUD) (well here comes the radio shack box sealed with silicone) |
06-07-2011, 08:12 PM | #5 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Be careful with overpacking the grease, it can rob power. The thicker marine grease made mine a lot slower when I had it packed full. All you need us a good coating if all the moving parts. Wes |
06-07-2011, 09:28 PM | #6 |
so i still have to decide what combo to get for a motor and speed control, i know im going to get a waterproff brxl, but im not sure what motor combo to go with. I was thinking of the 10t puller combo, but then i would have to upgrade the drive shafts, but would i have to upgrade anything else? i also was considering the sport combo, but how long will the motor last? |
06-08-2011, 02:00 PM | #7 |
tekin FXR with the 35t motor
06-08-2011, 02:35 PM | #8 |
Rock Stacker Join Date: Mar 2011 Location: Mpls
I am running a scx10 with a 10t and a lot of stock parts. Actually driveshafts have held up too, about 5 big battery packs run. However I adjusted my clutch a lot, I worry that a bind would break stuff quick I will tighten it up when I install my steel gears and whatnot...
06-08-2011, 02:48 PM | #9 |
i am running a BRXL and a tourqe master pro 30t and its a great mix of tourqe and wheel speed! a 10t would have a lotta low end balls for an scx-10 an yes the drive shafts would go bye bye if you go it bound up. |
06-08-2011, 03:05 PM | #10 | |
so if i got mip drive shafts would that be all i need? (thats with the 10t) is the 35t sport motor any good? if i were to buy the pro i just would rather spend the extra $10 to go with a puller combo and upgrade as stuff breaks. | |
06-08-2011, 03:22 PM | #11 | |
either way I would get MIP shafts and not worry, but the 10t is just a monster for this rig, I find the 30t to be the perfect all around motor on 2s for trails, rocks, and when I have got in a little mud. any more wheel speed would just get me into trouble, and any more tourqe I think the tranny out drives would be next. here is my pile of broken things as a result of having this 30t (kunckles and C's went when the cv pins bent/ broke) Last edited by 2500hdon37s; 06-08-2011 at 03:31 PM. | |
06-08-2011, 05:38 PM | #12 |
of course i do have a 10t puller sitting here not in use, if you would like me to try it......
06-08-2011, 07:17 PM | #13 |
06-08-2011, 09:07 PM | #14 |
well looks like for sunday im just going to put an xl5 esc and a 55t motor in it to play at the comp, will the stock gearing be fine for that?
06-08-2011, 09:16 PM | #15 | |
I think I might just see how the 10t does in mine tomorrow if i get some time just for S&G's! as for the 55t, it will be slooooooooowwww but still get ya by! | |
06-08-2011, 09:32 PM | #16 |
ok so stock gearing will work for the 55t if i dont get a 10t puller by then?
06-08-2011, 09:38 PM | #17 |
06-08-2011, 09:57 PM | #18 |
ok so is that a 48p 23t pinon right? thanks for the help |
06-10-2011, 06:40 PM | #19 |
06-11-2011, 09:23 PM | #20 |
well its done ill post pics up tommorow. i want to put a waterproof box that will hold a futaba reciver and a brxl and im not sure really how to mount it, and still keep the battery plate so i can use a 5000mah lipo and lower it alittle. |
