06-17-2011, 09:39 PM | #41 | |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
| Quote: http://www.rpphobby.com/ProductDetai...94BK&CartID=15 or this http://www.rpphobby.com/product_p/ax30494.htm | |
06-17-2011, 09:41 PM | #42 | |
06-17-2011, 09:58 PM | #43 |
Quarry Creeper Join Date: Sep 2010 Location: Central MN H-Town
I think my lower links are 6x106 but i've got spacers in to stretch it from that. Are you wondering drive shaft lengths??
06-17-2011, 10:01 PM | #44 |
im wondering about the lower link lenths, i already have mips on the way, it i got the same legth links as the uppers would the work or what? i would lik to keep it at the stock wb
06-17-2011, 10:46 PM | #45 |
no uppers are shorter, doesn't your truck already have aluminum links?
06-18-2011, 08:50 AM | #46 |
06-18-2011, 10:25 AM | #47 |
Then what's the problem? Stock aluminum links are fine
06-18-2011, 11:17 AM | #48 |
| its a 3link in the rear and i want to 4 link it, and i dont know what size links to buy, for the lower links
06-18-2011, 11:56 AM | #49 |
You're makin my brain hurt Mudbutt, lower links won't change for 3 or 4 link! You willhave to change the upper links to get the pinion angle you want and that will vary based on the 4link truss you choose. Trial and error
06-18-2011, 12:21 PM | #50 |
| wow now im confused lol so its the upers that are 3linked, ok then well what are the legths that i need for those with the dmgs mount?
06-18-2011, 12:24 PM | #51 |
I'm at work, ill measure mine when I get home. Longer than stock for now
06-19-2011, 12:08 AM | #52 |
Pebble Pounder Join Date: May 2010 Location: Ringgold GA USA
Hate to jump in on the conversation but i would just go with some 1/4'' brake line tube and 8-32 all thread with jato rod ends. Its cheap quick and fairly easy to do mine havent bent yet and i run the crap out of my rig.
06-20-2011, 08:24 AM | #53 |
06-20-2011, 06:40 PM | #54 |
120mm eye to eye rear uppers, homemade out of unobtanium
06-21-2011, 02:52 PM | #55 |
well im still trying to find a speed controler and motor i want to use, im still not sure wether to get the 10t puller combo, a vxl setup, or something else. It mostly is going to be a trail/mud truck, but im hoping to go to montana next year so hopefully whatever i chose will be good for there to. I will be running whatever battery it can handle, so i gess im looking for something with good wheelspeed, for climbs and mud racing, and still have some torq for crawling. I dont really care about drag break, my current setup doesnt have it and i do fine onthe rocks and trails.
06-21-2011, 05:02 PM | #56 |
Tekin fxr and a 35turn on 3s will be super.
06-21-2011, 05:04 PM | #57 |
06-21-2011, 05:25 PM | #58 |
| that's foolish, it's not a short course. Based on what you've thus far presented for motor esc combos you honestly are not the best calculator of speed they will produce. It is a scale truck not a formula 1 racer. insane speed is not something you want in that honcho. my .02 and if you were considering the 10t puller than you are miscalculating speed again TORQUE VS SPEED ??
06-21-2011, 05:31 PM | #59 | |
06-21-2011, 05:55 PM | #60 |
| Remember "scale", I never seen a Toyota going 200mph through mud, but that's the beauty of this hobby is that you don't really need to give two shits about anyone's advice and if having a Top fuel honcho floats your boat than give er hell, BUT with that being said when you find that it is too fast and hard to control when crawling rocks I will have to look at 12 more threads on how to make my honcho go slower. We have plenty of honchos in the club to compare to as far as wheel speed.. You could always go with a Holmes BRXL and a 30 or 35 turn motor and play with voltage 2s,3s ,4s ,5s and OMG 6s along with gearing you would have many options here 10t puller on 3s I dont know, but i do know that is a torque motor and not so much a speed demon...10t "PULLER"
