Thread: Problem with getting max throttle..
Old 04-08-2014, 01:40 PM   #1
Default Problem with getting max throttle..
Rebuilt a few different rc's over the winter. I had swapped in a Spektrum receiver into one of my SCX10's. After the swap I noticed my stock Axial 20t motor is now running slower than the stock Axial 27t motor in my Rubicon.
Any ideas on what may have changed? Along with the swapping in the spektrum recever I also changed the controller to a DX3C. Ive tried resetting the settinging on the DX3C and also re binding. Still not turning as fast.
Is there any way to reset the ESC? I read tsoemthing about the ESC determining what the max throttle is by how much you pull the trigger when turning it on? or something along those line?
warpig602 is offline   Reply With Quote
Old 04-08-2014, 08:37 PM   #2
Default Re: Problem with getting max throttle..
Maybe throttle percentage adjustments on the radio itself?
6sharky9 is offline   Reply With Quote
Old 04-08-2014, 11:41 PM   #3
you need to re calibrate your esc to your radio.
1. turn on your radio.
2. hold full throttle on your radio and turn on the esc.
3. you will hear some slower beeps.
4. when it starts beeping fast go straight to full break.
5. wait till fast beeps again.
6. let go of the break.
7. let it finish beeping and the esc will reset.
8. your esc should be programed to your radio now.
http://docs.axialracing.com/instruct..._and_Specs.pdf
some87 is offline   Reply With Quote
Problem with getting max throttle.. - Similar Threads
having problem with throttle? lildjloop Axial AX-10 Scorpion 17 04-28-2009 02:22 PM
Throttle Curve? Mamba Max? run2jeepn Electronics 10 03-06-2007 08:05 PM
Mamba Max throttle curves k9popo Chit Chat 0 02-02-2007 09:23 PM
throttle problem octigonwallrus Electronics 5 09-10-2006 12:56 PM
