02-18-2013, 04:53 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Long Island, NY
| Front axle wobble
I was looking at my truck before and noticed my front axle wobbles front to rear. I took a closer look and noticed the Y link in the front is the problem. From the front of the truck, there is a long screw that goes through a piece on the axle and into the Y link. There seems to be some play in there. I took it off and put it back together, but it's still loose. A guy at my LHS said it's a common problem. How can I fix it and get rid of the play in there?
02-18-2013, 05:00 PM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
Replace the stock piece with a metal piece would make it better & last longer. Another thing you could look into is four linking the front.
02-18-2013, 05:07 PM | #3 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: Front axle wobble
It's the ball inserts in your rod ends and y-link mount that likely has the play. Axials rod end inserts are known to have some slop. 4-link with more precise rod ends and everything should be nice and slop free.
02-18-2013, 05:08 PM | #4 |
Which piece are you talking about? The one that goes on the axle or the small ball that clicks into it? I am buying a full titanium link conversion soon. |
02-18-2013, 05:14 PM | #5 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Use a 3mm washer and shock o-ring on both sides of the 3 link ball end to take up the slop.
02-18-2013, 05:17 PM | #6 |
If that's the route you go, and they use the Revo ends, you should be good to go for awhile. Wear and tear is normal for anything that's moving, but after making a set of links using the Revo ends my axles are completely free of slop. How long it remains nice and tight is another question, but that's why I bought plenty of rod ends - for those obsessed with slop, they are consumables.
02-18-2013, 05:23 PM | #7 |
| Re: Front axle wobble |
02-18-2013, 05:38 PM | #8 |
| Re: Front axle wobble Yes, they are the same one used throughout the truck in the steering/suspension links and shocks. The one in the 3 link mount probabaly isn't the only one that has developed some slop, but is the most likely since they aren't really designed to handle loads on that axis.
02-18-2013, 09:04 PM | #9 | ||
| Re: Front axle wobble Quote:
Front axle wobble - Similar Threads | ||||
Narrowing front Wraith Axle for front of scx10 | rusty577 | Axial SCX-10 | 12 | 02-02-2013 10:30 PM |
LNC front axle teardown/axle shaft removal guide? | LowLock | Team Losi Comp Crawler | 1 | 05-22-2011 09:31 PM |
XR10 Left front wheel wobble question | xv-townboy | Axial XR10 | 17 | 12-24-2010 02:18 PM |
front steering linkage behind front axle kit? | slip408 | Axial AX-10 Scorpion | 8 | 09-14-2008 01:16 AM |
