06-17-2013, 06:18 PM | #21 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| Re: Dingo gets a new home and new life. A.K.A. project old school Ok I added the rear bumper and made a new mount for it. In the photo of the rear mount I flipped the bolts over so the bumper will hide them. I don’t know how i feel about the front bumper. So if u will let me know if it’s a go or a no go. I will be fabricating a set from sheet metal and tube. I’m using teas as a starting point. |
06-20-2013, 04:27 AM | #22 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Tonight I took the plastic upper links out of the rear end of my truck and dropped in the factory aluminum 6x91mm links. I also had time to work on the front bumper some more so here it is. |
06-22-2013, 10:30 AM | #23 |
| Re: Dingo gets a new home and new life. A.K.A. project old school update To day I removed the 3900kv Castle Element. The new power plant is a Tekin Rs esc and a Novak Ballistic 21.5 brushless sensored motor. The gearing is now 20t pinion/90t spur. I also did a mod to my esc fan box. I took an extra lid I had and fitted it to the fan lid to make it taller. I had to cut the front lip of the box to make every thing work |
07-01-2013, 08:50 PM | #24 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Ok so as I was working on old school last week I put the 93 tooth spur on and did not like it so I gave it to a friend. As I was putting the 90 tooth spur back on the new Tekin rs went up in smoke. The damage was the esc box and sensor wire to motor. I like the tekin esc's but I have had 2 go up in smoke with in the past 6 mounts. I hade a extra novak rooster crawler esc and 27t motor so that is runing the truck for now. I also added some mip drive shafts to the mix. |
07-04-2013, 11:04 AM | #25 |
Rock Stacker Join Date: May 2013 Location: Phenix city
look at that ridgecrest photo bomb
07-14-2013, 08:56 AM | #26 |
| Re: Dingo gets a new home and new life. A.K.A. project old school |
07-14-2013, 10:08 AM | #27 |
Newbie Join Date: Jul 2013 Location: The Shire
After reading threads with pics of awesome mods like this, I get super motivated. Thanks!
07-23-2013, 09:51 PM | #28 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Update I have added the Pro Line Interco TSL SX Super Swamper 1.9 tires in G8 compound. I tested the 4.30 size tire for my boy upcoming trail truck build. I liked the tire so much I got me a set of the 4.75 size tire. I did however modify the foams that came with them. i cut about 3/4in of of each foam befor mounting. Ok im done rambling photo time. |
08-04-2013, 09:04 PM | #29 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Im putting down the tools for the night. This is my progress a little fine tuning and she will be good to go. |
08-07-2013, 08:25 PM | #30 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Well it just needs paint now. The coustom gopro axial frame mount is done. I also made a blind for the inside of the body so you dont see the esc and servo when on a run. |
08-08-2013, 04:09 PM | #31 |
Newbie Join Date: Jan 2006 Location: Hot Springs
What color mix green is that?
08-08-2013, 07:57 PM | #32 |
Newbie Join Date: Feb 2012 Location: Columbus
With that Ford body what is your wheelbase of the truck and of the body? What links length are you using? I've been thinking about buying one of those bodies.
08-17-2013, 08:30 PM | #33 |
08-17-2013, 08:38 PM | #34 | |
| Re: Dingo gets a new home and new life. A.K.A. project old school Quote:
10-06-2013, 08:41 PM | #35 |
| Re: Dingo gets a new home and new life. A.K.A. project old school After a few runs |
12-29-2013, 06:18 AM | #36 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Up Date I have added a Vanquish Aluminum Transmission Housing to the mix of parts in my rig. With the Gears from Robinson Racing on the inside its just a sweet mix of parts. |
12-29-2013, 08:31 AM | #37 |
| Re: Dingo gets a new home and new life. A.K.A. project old school Well im calling this project done. The truck works really well and only has one true draw back that is the short wheelbase. I like the truck so much im now in the process of building a long wheelbase version of this truck. |
Dingo gets a new home and new life. A.K.A. project old school - Similar Threads | ||||
What is the Dingo body based on (real life truck) | slitcher | Axial SCX-10 | 8 | 04-02-2014 07:42 PM |
small 1st test at home new dingo kit | greggreg2011 | Scale Videos! | 2 | 04-25-2013 09:14 PM |
BrAtKo's Camel Dingo II (home made D90 grille) | BrAtKo | Axial SCX-10 | 15 | 07-05-2012 11:56 AM |
Life sucks, i got rejected by the hottest girl in school. | shadowrejects | Chit Chat | 84 | 09-28-2009 06:30 PM |
