09-29-2013, 07:17 PM | #1 |
Newbie Join Date: Sep 2013 Location: san antonio tx
| Motor glitch after dipped in water!! Why?
So I went on a trail run and after I ran through a puddle the motor started making a Arcing sound and then it stopped moving, went home used some electric cleaner and it came back to life. What could of caused it and I thought all motors where waterproof, my friend ran through the same water and nothing happened
09-29-2013, 07:21 PM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: Bowling Green KY
What kind of motor are you running? Brushed motors will run ok in water but dirt and debris can cause what you described. Brushless motors you can dip the sensor board in corrosion x and it'll run typically with no issues. But motors aren't water proof..... Sent from tinker room pro |
09-29-2013, 08:47 PM | #3 |
I'm running the novak rockstar 35t
09-29-2013, 09:01 PM | #4 |
Quarry Creeper Join Date: Apr 2009 Location: Lynnwood
| Re: Motor glitch after dipped in water!! Why?
The clearance inside of a motor is pretty small, so you could have sucked in a peice of sediment that stopped te motor, once you cleaned it out it was fine.
Motor glitch after dipped in water!! Why? - Similar Threads | ||||
Motor Glitch Problems | Spucknit | Electronics | 6 | 09-01-2007 06:12 PM |
rx glitch caused by motor? | jbrandt | Electronics | 5 | 08-11-2007 12:58 PM |
Chrome Dipped Tuber | Thorsteenster | Chit Chat | 16 | 10-11-2006 02:45 PM |
why is the front tub always dipped? | STANG KILLA SS | Chit Chat | 17 | 09-26-2006 10:15 PM |
Plasti-Dipped My servos | AdamF | Electronics | 18 | 03-11-2005 05:14 AM |
