12-10-2013, 07:02 PM | #1 |
Rock Stacker Join Date: Apr 2013 Location: San Diego
| Scx 10 issue
I am having a problem with my newly bought scx10 and I do not know what to do. So i hooked up my reciever, not the axial one, and my transmitter, not the axial one. All of the electronics are stock besides that though. i start my car and only my steering works. I try binding it by the gas, brake, neutral thing but i cannot get the the brake. i go full throttle and i here the rings but when i try brake, nothing happens. What should I do? Thanks!
12-10-2013, 09:58 PM | #2 |
Rock Stacker Join Date: Feb 2013 Location: NC
| Re: Scx 10 issue
what transmitter you using?
12-12-2013, 10:31 PM | #3 |
| Re: Scx 10 issue
A exceed mad torque remote and transmitter. I think that may be it.
12-12-2013, 11:02 PM | #4 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
| Re: Scx 10 issue
Make sure all ur receiver plugs are facing the right way
12-13-2013, 07:34 AM | #5 |
Newbie Join Date: Nov 2012 Location: Tampa
| Re: Scx 10 issue
Make sure your throttle and steering trims are set to zero and then calibrate it. I just had the same problem with my AE-2.
12-13-2013, 09:01 AM | #6 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| Re: Scx 10 issue
Turn on Rx, apply full throttle. turn on car, it should beep. when it does a double beep that's diffrent, apply full reverse. should double beep again after a second or two, let go of trigger for neutral.. should beep a couple more times then stop. car should now work. sometimes the settings on the speed controller get messed up. |
12-13-2013, 04:59 PM | #7 |
| Re: Scx 10 issue
THANK YOU EVERYONE! It finally works! Big Thanks!
Scx 10 issue - Similar Threads | ||||
SCX-10 AE-2 ESC issue | allenscania10 | Axial SCX-10 | 8 | 08-27-2016 08:08 AM |
scx drivetrain issue | wheelinndealin | Axial SCX-10 | 9 | 03-05-2013 10:51 PM |
MMP issue... i think i'm the issue. | concretejungle | Electronics | 12 | 08-13-2012 02:52 PM |
ESC or Motor issue with my SCX | bbaxter51 | Axial SCX-10 | 8 | 12-12-2011 12:47 PM |
