01-12-2014, 02:22 PM | #21 |
Rock Stacker Join Date: Feb 2013 Location: Asheville
| Re: First Shafty, Tans skipping?
The pin holding the slipper is ok, saw it last night while checking the trans. Rear axle pinon can be spun very easily and spins for a few seconds after letting go. the front spins but stop immediately after i let go and feels a little stiffer. It's only a few weeks old only been on the trail twice maybe 6 hours total runtime opening up the front right now see whats going on... Last edited by Cr4wl3r; 01-12-2014 at 03:00 PM. |
01-12-2014, 03:29 PM | #22 |
Aahhh there is a gremlin hiding somewhere in here and i cant find him! Front axle is open and gears look great, locker seems to be fine holding tight, axle rods are nice and straight, grease was on the gears, no dirt, rust, or missing screws. ....im stumped. don't know what else except motor |
01-12-2014, 06:36 PM | #23 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Have you tried removing the pinion from the motor and turning the spur by hand with everything else installed?
01-12-2014, 10:27 PM | #24 |
Removed the pinon from the motor everything else hooked up, pushed it by hand back and forth on hard floor and could still feel the hopping, disconnected the rear drive shaft and pushed it back and forth still could feel it. disconnected front drive shaft pushed it back and forth still felt it. So after searching the hole vehicle it lead me to believe it was back in the tranny somewhere, just opened it up again and everything is in great working order. putting it back together and if it drives and climbs the rocks in the yard then guess im done till it breaks...idk really strange |
01-13-2014, 02:06 PM | #25 |
Put it all back together and this is the result video still performs SCX10 Test after rebuilding - YouTube Brought her back in and took the body off, played with the throttle a min and notice a slight wobble in the spur gear got a video of it. Spur Gear Wobble - YouTube |
01-13-2014, 06:33 PM | #26 |
| Re: First Shafty, Tans skipping? |
01-13-2014, 06:36 PM | #27 | |
| Re: First Shafty, Tans skipping? Quote:
01-13-2014, 09:18 PM | #28 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
01-13-2014, 10:38 PM | #29 |
With no motor and no drive shaft i cant feel anything it seems smooth. but once you hook up a drive shaft, does not matter front or rear or different drive shafts it still wobbles. going to get some washer and shim behind the slipper plate. when i can gonna pick up a bearing kit. maybe a bearing has gone bad in the trans. Going to open the rear axle but it seems more fluent than the front so... Do i shim the pinons from inside the axle housing? |
01-14-2014, 12:03 AM | #30 |
Pebble Pounder Join Date: Jan 2014 Location: Adelaide
yeah take the pinion out put a shim behind the gear and slide it back into the bearing
01-14-2014, 01:33 AM | #31 |
Newbie Join Date: Aug 2013 Location: Israel
On my Rubicon it also skips - but only when you hold it in the air and not while in the field i think its normal and as something to do with the build in slope in the drivetrain (the same thing kept happening after i changed to MIPs and universals and new wheels/hexes) |
01-14-2014, 09:55 AM | #32 |
How many washers should i shim behind the pinion?
01-14-2014, 10:02 AM | #33 |
Pebble Pounder Join Date: Mar 2009 Location: buford
I sheared the locking ears off my iron cross locker. I thought it was the trans skipping for a long time. It would skip in a bind.
01-14-2014, 10:27 AM | #34 |
As far as the front goes the locker was in great shape, i've yet to open the rear axle but its never presented a problem in the rear, will be opening it anyways soon. When i open the rear should i go ahead a shim that pinion too? Going to shim the slipper plate and go ahead and get the metal gears from Robinson Racing, cuz i feel like the gears are going to go at some point because of this issue. |
01-14-2014, 05:29 PM | #35 |
Shimmed behind slipper plate, reduced the wobble in the spur but didn't fix the problem. Removed the rear axle and rolled her back and forth with everything else hooked up problem still there. Opened up the rear axle anyways just to inspect things. Everything was in good shape... Soo gonna get fast eddy bearing kit and Robinson gears and see if that fixes it |
01-14-2014, 05:43 PM | #36 |
What happened to "just use it until something breaks"? You're chasing a gremlin man...let it go. Wait till something breaks.
01-14-2014, 08:05 PM | #37 |
ya your right, its just aggravating. gonna take it to the trails Sunday and really put it to the test, see how it does.
01-15-2014, 02:17 AM | #38 |
Drive it like you stole it. Ignore the gremlin for now... Lol Sent from my iPhone using Tapatalk |
01-15-2014, 03:04 AM | #39 |
Rock Crawler Join Date: Oct 2010 Location: Nor Cal
I'm not sure if you fixed your problem but after reading everything that you posted I'm pretty sure your problem is because of the lift you did on this rig. The driveline pinion angle looks fine but it's the driveline angle by the transmission front and rear look too steep. If you take off the lift kits part and install the shocks in it's stock location and the sound and binding goes away then you would have found your problem. The Axial WB8 drivelines tend to have the same problem you are encountering when pushed past it's limits. An easy fix and what I would recommend fix would be to get a set of MIP driveline they are much more durable and can handle a more steep driveline angle. Hopefully this all help. |
01-15-2014, 06:10 PM | #40 | |
Rock Stacker Join Date: Jun 2013 Location: Wendell
Agreed with above post. ^^^^ But also the way I am understanding your post here. The raise mark should line up with the other driveshaft not the pin on the joint. If that make sense? It sounds like from your discription the driveshafts are installed with the weight lining up and not counter balancing itself. Hence the reason for the marks on the shafts Quote:
First Shafty, Tans skipping? - Similar Threads | ||||
RC skipping on water | venomous98 | Non Crawler RC's | 4 | 03-03-2011 03:42 PM |
tans swap | davebarlow13 | Losi Mini-Rock Crawler | 2 | 08-25-2009 09:59 PM |
Belt skipping | airranger | Newbie General | 4 | 08-20-2006 11:21 PM |
