Thread: Upgrades & mods to my JK rtr, good or bad?
Old 01-14-2014, 08:35 AM   #1
Default Upgrades & mods to my JK rtr, good or bad?
So I have been working on my JK rtr I got for my birthday and I am getting it ready for the axial fest of 2015.(Yes I know its next year, but I can't make it this year). So I began doing a lot of mods. and here they are:
- Moved battery plate to frame; zip tied to front shock towers
- Moved receiver box to the back and ziptied to the frame
- Balloned and plasti-diped my esc
- Balloned my receiver
- pluged the holes in the stock wheels with silicone
- Marine greased all of the bearrings on the inside (in the axles)
- Four-linked the front
Upgrades I have on it
- axial aluminum steering drag link etc.
- axial aluminum links (upper,lower etc).
So those are the mods and upgrades and yes I know there are plenty more, but next Ill tell you my upcoming upgrades:
- 1.9 Pro-line XL super-swampers
- 1.9 axial beadlocks
- Savox 0231 WP servo (around 208 oz. at 6.0v)
- CC BEC 10 amp
- Pro-line scale accessories
- Rc4wd 100 mm king shocks
- level3 droop kit
- A new jeep body (I will be doing a custom body)
So my upgrades go on and on and they are basic. But know I will have to undo all my balloning to plug in my BEC and the headlights I plan on running. With a BEC can I just use a Y-harnesses to plug both my lights and BEC in? I will use my stock esc until it fails, then to tekin. I already know that driving water can cause it to rust but I have marine greased it a lot but not too much. With the body I will paint a bright green (its the same TYPE of body it has). Then with the proline accesories it should add a little scale to it. So what do you guys think of my upcoming upgrades? I sound like a noob right know but I need to know this before I order and start with the upgrades.Oh almost forgot How do I waterproof a BEC? Thanks, - axial 4x4 crawler
axial 4x4 crawler is offline   Reply With Quote
Old 01-14-2014, 12:07 PM   #2
Default Re: Upgrades & mods to my JK rtr, good or bad?
Can some one answer my simple question on waterproofing the BEC and running a y-harness with lights. Im in a hurry to order what I need, and I just need to find out if the y-connector will work on the ch. 3 port with a BEC and a axial simple LED lights! and some opinions would be nice also, thanks again.
Old 01-14-2014, 12:24 PM   #3
R2j
SORRCA Committee Member
R2j's Avatar
Check this out for BEC wiring........
Definitive wiring diagrams for BECs Rx Servos Motors etc.
R2j is offline   Reply With Quote
Old 01-14-2014, 12:31 PM   #4
Scale Detail Engineering
I coated my bec in conformal coating and threw it in a balloon... so far so good.
johnnyh66 is offline   Reply With Quote
Old 01-14-2014, 01:42 PM   #5
Thank you, this is very helpful!
Old 01-14-2014, 01:44 PM   #6
That sounds like a good idea, I could dip it plasti-dip and the put in the ballon. But I think I could also use silicone on the ends of the blue cover, I'll do some more investigation on this tonight but I still have to order my BEC.
Upgrades & mods to my JK rtr, good or bad? - Similar Threads
CR-01 Upgrades/mods Giznad Tamiya CR-01 11 03-18-2013 09:31 AM
First mods/upgrades? CrawlAR Redcat Crawlers 23 01-20-2013 01:46 PM
Good & bad ! Nitrofin Chit Chat 14 05-02-2009 12:40 PM
