03-17-2014, 06:23 PM | #1 |
Newbie Join Date: Feb 2014 Location: Duluth
| I need some help folks! I have video and have tried trouble shooting myself.
So I finished building my scx10 and finally got my esc so I wanted to test it out quick and this is what happened. SCX10 shaking issue. - YouTube I pulled drive shafts, both front and rear axle will do the same thing independently. Without any drive shafts it's smooth. I pulled the rear axle all apart, found a carrier bearing a skew a tad bit, hardly noticeable, pressed it flush, reassembled same exact issue. I'm suspecting its trans related now but only under load. I messed with the slipper clutch, nothing changed. I noticed the slipper shaft does move in and out a bit more than a 1/16". Ultimately I'm at a loss and have a ton of time and ching into this thing and am very frustrated. Please if anyone can point me in the right direction I'd greatly appreciate it. Also I compressed the rear axle when only it was being driven, to create a more favorable drive shaft angle, and it still did this exact same thing. Last edited by Z8APOWER; 03-17-2014 at 06:25 PM. |
03-17-2014, 06:27 PM | #2 |
Quarry Creeper Join Date: May 2005 Location: Ontario, Canada
| Re: I need some help folks! I have video and have tried trouble shooting myself.
It sounds and looks like something is off alignment. Or somewhat binding. Try running the motor, but compress the suspension front and back and see if it runs more smooth. That way you can determine if your driveshaft angles are to steep or not. Maybe it just needs time to break in lol. Sorry i cant help much more
03-17-2014, 06:42 PM | #3 |
I did attempt that with no difference unfortunately, thanks for the pointers though.
03-17-2014, 06:59 PM | #4 |
Quarry Creeper Join Date: Oct 2011 Location: Westport Island
Check your driveshaft indexing I believe both of the large pins of the cv joint need to be aligned with each other ( hope that make sense) my son in laws new rig did the same thing, we indexed the shafts and problem went away. Sent from my iPhone using Tapatalk |
03-17-2014, 06:59 PM | #5 |
Newbie Join Date: Jan 2011 Location: St. Clair Flats
Try aligning the axles. There are little dash marks that need to be lined up on each, if they are not aligned it will shake at low speeds. Hope helps.
03-17-2014, 07:04 PM | #6 |
I wanna be Dave Join Date: Nov 2007 Location: roseville
From the vid looks like the drive shaft angles are pretty steap, that will cause chatter. try pulling the shocks out put it down and see if the chattering is gone. You might need to kick the pinions up.
03-17-2014, 07:16 PM | #7 |
I aligned the index marks everytime I installed the shafts but never payed attention to the ujoint orientation, I'll check that. I fully compressed the rear axle with only that drive shaft in and it still did it. I'll double check it though, thanks again everyone.
03-17-2014, 08:28 PM | #8 |
Quarry Creeper Join Date: Mar 2014 Location: Masshole
I am not sure if this would cause that problem but you did not mix up the links? Shorter ones in the front, longer ones in the back? When you look at the axles are the straight across the chassis or are they cocked at an angle. If they are at a slight angle look at your links. Make sure you did not mix them up with a short and a long in the front and a short and a long in the back. |
03-17-2014, 08:28 PM | #9 |
Skybolt you are my saviour! Sure as sh*t that's what it was. Seriously thank you for the input! It runs perfectly smooth now! I have no idea what I did to mess up the index marks during assembly. What a relief now that it's resolved!!!
03-18-2014, 02:00 PM | #10 |
Newbie Join Date: Mar 2014 Location: Soldotna, Alaska
Looks like driveshaft angle to me. Probably binding a little.
I need some help folks! I have video and have tried trouble shooting myself. - Similar Threads | ||||
Trouble Shooting Help | Nosedive | Texas | 12 | 02-24-2012 08:08 AM |
EVX2 trouble shooting..help | smm_cbf | Electronics | 0 | 07-09-2009 10:50 PM |
Trouble Shooting Rx? | chevihemi | Electronics | 9 | 03-28-2009 11:06 PM |
need some trouble shooting help... | BeerMonkeY | General Crawlers | 0 | 08-29-2006 03:02 PM |
Maxx Trouble shooting | eb76adam | General Crawlers | 7 | 12-09-2004 04:20 PM |
