10-08-2014, 10:16 PM | #1 |
Rock Stacker Join Date: Aug 2014 Location: NYC
| Whats a good upgrade trans for the scx10
I was thinking about swaping out my trans. My uncle ran a r2 trans in is gen1 custom ax10 and that thing always got the job done. im not sure what to go with for the scx10. Also whats the pros and cons of 2 speed trans
10-08-2014, 10:22 PM | #2 |
| Re: Whats a good upgrade trans for the scx10
pro- you can have a go fast and really low crawling gear. can decrease motor temps if used properly. con- adds to driveline slop and the scx-10 isnt much of a handler with speed. Or you can cook a motor if used improperly. Personally I swapped in an Axial dig transmission case (ax-2/ wraith), dig unit, and steel internal gears. Works great and is more capable than a 2 speed will be. You can turn sharper, use the dig to get the front to grab on a climb, and have 2wd if you use the freewheel option. |
10-08-2014, 10:30 PM | #3 |
I would just get steel gears Sent from my VS980 4G using Tapatalk |
10-08-2014, 10:38 PM | #4 |
^ X2 nothing wrong with the stock tranny. two speed would be ridiculous for a crawler... unless it were geared low and compound low. Lol/jmo for the rock racer/bouncer... suppose reckless speed is a thrill Lol volt up - gear down... torque rules |
10-09-2014, 07:01 AM | #5 |
Quarry Creeper Join Date: Dec 2013 Location: Atlanta
| Re: Whats a good upgrade trans for the scx10 until you strip out the mounting holes...then its time for aluminum! I went cheap through Asiatees and got a GCM tranny and metal gears for less than 40 bucks total, no problems so far, I don't trust all cheap china parts, but these seem to be fine, all parts fit together great and look good doing it |
10-11-2014, 12:34 PM | #6 | |
Newbie Join Date: Jun 2013 Location: two harbors
| Re: Whats a good upgrade trans for the scx10 Quote:
Whats a good upgrade trans for the scx10 - Similar Threads | ||||
axial trans upgrade question | ben h | General Crawlers | 3 | 03-26-2014 06:57 PM |
RSMC Trans Upgrade??? | 89redranger | Losi Micro-Rock Crawler | 4 | 07-11-2013 08:34 AM |
RADIOS: Whats needed and whats a good price tag | losikid | Electronics | 3 | 02-08-2011 10:20 PM |
Whats a good setup for a scx10 motor/esc wise? | traxxas4fun | Axial SCX-10 | 7 | 07-12-2010 08:11 PM |
whats hot, whats not. post good and bad setups and products | TomEGunn | General Crawlers | 9 | 05-28-2009 07:29 PM |
