Thread: 1976 Ford Courier Build
Old 08-19-2015, 02:17 PM   #1
Default 1976 Ford Courier Build
Growing up, my grandfather had a blue Ford Courier that made so many trips to the Agway and the lumber yard I'm pretty sure could drive itself there and back on its own. I loved that truck. Even as a little kid my grandfather would let me shift while he held down the clutch.
My grandfather is also partially responsible for me getting into R/C. His neighbor across the street had a Tamiya Hornet that he would race up and down the road. It was the coolest thing my 11 year old eyes had ever seen. I studied the Tower Hobbies catalog obsessively, saved my money and picked up a Tamiya Falcon when I was 12. I was hooked.
Enter my dad. He's always been super supportive of my R/C interest. When my Falcon kicked its rear dogbones for the umpteenth time, he went halfsies with me on a Kyosho Ultima. He thought it'd be a great bonding experience. It probably would have been had I not worked around the clock to build the thing before he even had a chance to sit down. He painted the body.
Time to make it up to him! When I recently found out Pro-Line used to make a Ford Courier body, I knew I had to make a version of my gradfather's truck as a surprise for my dad. I managed to track down a body from Australia. The wheelbase is right around 11.5", so I picked up a Dingo kit and a bunch of other parts to get ready for a build.
Axial SCX-10 Ford Courier Build by johnny anguish, on Flickr
I'd love to make it a real stock looking truck, but that's probably not practical, given they were 2WD compact trucks. I want this thing to be relatively trail-worthy, so my dad will actually drive it (also the reason why I went with an SCX-10 over, say a TF2... readily available replacement parts!). In the end it will likely be "inspired-by" my grandfather's truck more than a replica. Let's hope dad likes it so the kids and I can go out trailing with Grampy.
Oh, here's some of my inspiration...
JohnnyAnguish is offline   Reply With Quote
Old 08-19-2015, 06:11 PM   #2
Default Re: 1976 Ford Courier Build
Axles
Got them set up with the 4-link trusses here. As you'll see, I go back and forth. The truck is currently set up with 3-link front and 4-link rear. We'll get to that eventually...
Shocks
Box stock. These seem a lot stiffer than when I built my G6 kit. Do the different kits come with different spring rates?
Axles & Shocks
Ta-da!
Last edited by JohnnyAnguish; 08-20-2015 at 11:50 AM. Reason: Updated image links.
Old 08-20-2015, 07:28 AM   #3
nice body wonder if they are still available...Long story short.When i was 17 my father bought the Ford Courier 2WD.It was at the Ford dealership more then it was in the drive way. and it was yellow too....Maybe the burn outs at the wharf would explain it.lol....
great start will be watching this ....Now I have to go look for a ford courier body..Ya I'm a ford guy....
rustneversleeps is offline   Reply With Quote
Old 08-20-2015, 11:32 AM   #4
Sooo... this was fun. Once I got the transmission together, I noticed something odd. My Dingo kit had the drive gear shaft for the new upgraded dual slipper clutch, but the rest of the parts were for the old style slipper. Oops.
Old 08-20-2015, 04:51 PM   #5
I had one like this when I was in high school.
Reddog95 is offline   Reply With Quote
Old 08-20-2015, 05:02 PM   #6
I'd love to have my grandfather's back, but this'll have to do.
Old 08-20-2015, 05:50 PM   #7
going to be a sweet build, i'll definetly keep and eye on this build. ahh yes, the good old days. I remember couriers, the old Datsun bullet sides, the later years mazda sundowners, and their ford cousin. a guy I know found an early 70's Datsun bullet side that had been in a barn since the early 80'.30k original miles, had new exhaust,radiator, and hoses installed, then was parked.stole it for $500.keep up the good work, can't wait to see the finished truck.
flatfoot is offline   Reply With Quote
Old 08-20-2015, 07:24 PM   #8
Great tribute build!
school boy is offline   Reply With Quote
Old 08-21-2015, 01:10 AM   #9
Was checking ebay but couldn't find one 'Ford Courier".anybody have a link to were i could buy one..there was no luck at pro-line web site...
Old 08-21-2015, 08:54 AM   #10
Mine came from Australia. Can't remember where exactly. I remember using the item number to find it: PR3197-00
I think some distributor there found a box of 'em lying around, because they've been discontinued for a long time. When I contacted Pro-Line, they said it must be leftover stock because they're not being reissued. Lucky timing.
Old 08-21-2015, 11:15 AM   #11
While I was waiting for the appropriate parts to finish off the transmission, I forged ahead with the rest of the build. Got the chassis together...
For a wheel/tire combo I'm starting out with 1.9 Dirt Grabbers on white G Made VR01s. There are only 3 pictured here because I tried a coat of matte clear on one of them and ended up not liking the results. Size and look wise, I think the Dirt Grabbers will work well. I'm a little worried about performance, but there aren't a ton of "stock" looking options out there. The wheel arches on the Courier body are really small. I'm trying not to chop it up too much. I also have a set of the metal G Made SR03 wheels which would add some nice weight down low, but the look isn't quite right. All of these decisions are subject to change once we get this thing out on the trails.
Here's everything bolted together. If you look carefully, you'll see it's back to a 3-link setup here. The stock plastic links are too long to use as uppers in a 4-link setup with the short wheelbase. You end up with funky pinion/steering angles. You might be able to get away with it in the rear, but the front was a no-no.
Old 08-21-2015, 10:17 PM   #12
Hey man thanks for the part number without it I would have never of found it.
But looks like just maybe these bodies were only distributed in Australia only.
they have some old 1966 Ford f100 i never seen before to.
well you check it out.
just a couple of hobby shops i found AU.
https://www.google.ca/url?sa=t&rct=j...9HVEZS8DHetr0A
this next hobby shop has them on sale...
https://www.google.ca/url?sa=t&rct=j...HJTKK3aY65vZGg
Old 08-22-2015, 06:40 PM   #13
Eventually got the parts to finish off the dual slipper clutch. Assembled and installed...
Old 08-23-2015, 06:33 AM   #14
Nice clean build so far. My dad had a Ford Courier when I was a kid.
HDMM is offline   Reply With Quote
Old 08-23-2015, 05:06 PM   #15
Here it is with the body roughly trimmed out. I've since enlarged the wheel wells a little, but I'm trying not to chop it up too bad. I'd love to have it sit lower, but that's about as low as it'll go if I want to run bumpers and sliders (and not trim up the wheel wells even more). I was originally going to run bumperless for a stock look, but there's no rear bumper on the body, so I'd at least have to have a rear bumper. And once that gate is open, I might as well go all out...
The electronics are in and it's runnin':
  • Axial 27t motor
  • HobbyWing QUICRUN 1060 ESC (swapped on a Dean's connector)
  • Hitec HS-5646WP servo (the Savox I originally picked out was a little to big and the cable was binding on the frame)
  • Castle 10A BEC
  • Spectrum SR410 receiver
Also of note, the rear is 4-linked again. I added a couple of spacers to the rear links to get the wheelbase exactly how I want it (rear wheels centered in the wheel wells, fronts ever so slightly forward to try to get those smaller tires onto the rocks). That meant I could run the plastic upper links from the kit in the rear and still have a good pinion angle.
Old 08-23-2015, 05:16 PM   #16
making good progress.looking good.nice choice on wheel/tire combo.
Old 08-24-2015, 11:42 AM   #17
OK, now that this thing is running it's time to have some fun!
The Pro-Line body is really nice quality (thick!), but it doesn't have a whole lot of front end detail. Adding some three dimensional lights to the front should help with the overall look. Plus... lights! My dad digs the lights on my other scalers, so the Ford is definitely getting some.
I used some Axial buckets and lenses. The size is just about perfect. Once these are painted silver they should blend in pretty well.
Old 08-24-2015, 11:44 AM   #18
That is sweeeeeet
Sent from my SAMSUNG-SM-G900A using Tapatalk
gbaileyo7 is offline   Reply With Quote
Old 08-24-2015, 01:05 PM   #19
Location: Taylors Falls just hanging with the MNRCRC crew.
I had a Ford Courier I bought it new it had a Mazda chassis and suspension with a big Ford overhead cam four cylinder motor 4 sp tranny and sheet metal. I lowered mine slightly added a body kit, headers, exhaust system, audio, wheels and tires it was a very fun reliable little cruiser pretty quick too.
I was able to pick up two Australian Courier bodies great score thanks.
Stormin2u is offline   Reply With Quote
Old 08-25-2015, 11:23 AM   #20
Gotta have a driver!
When I picked up the Courier body, I wondered if I could get an interior to fit. The Bruiser interior looked pretty close, so I took a chance thinking I might be able to get it to work with a little trimming. Turns out, it's a very good fit! Phew. I just had to notch out the bench seat for the transmission. I also had to get a stick shift in there, since I have such fond memories of my grandfather letting me shift when I was just a kid. This one came off a Wraith spare parts tree.
Ready for paint!
1976 Ford Courier Build - Similar Threads
1967 Ford Courier Class-2 Build waggaclint 1.9 Scale Rigs 21 05-30-2015 12:03 AM
K2-3L 76 Ford Courier BGGruff 1.9 Scale Rigs 68 01-22-2008 10:45 AM
Ford Courier WB?? Kyle Hess Paint and Body 4 05-27-2007 10:42 PM
Ford Courier... Double J Chit Chat 18 07-27-2006 09:14 PM
