02-11-2017, 08:57 PM | #61 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
| Re: Xtra Speed axle
Installation was smooth. Everything fit well except (as some have mentioned) the inner bearing was super tight. I had to sand a bit in one axle. I just pushed harder and fought more on the second until it popped in. I had picked up the ARB diffs a while back; but, I have been waiting to install since I thought I would eventually end up with these axles. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
02-11-2017, 09:28 PM | #62 |
Rock Stacker Join Date: Sep 2016 Location: USA
| Re: Xtra Speed axle Hey shawns303, i was wondering if i could get some info on exactly what mods you had to make to fit the ar60 version on your bomber? I realize this is the wrong section but maybe you could throw up a new thread in the bomber section? I looked but didn't find one. If not maybe pm me? Thanx a lot |
02-16-2017, 10:01 AM | #63 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
| Re: Xtra Speed axle
After some serious beating, only some normal scuffs. I have to highly recommended these! Sent from my SM-N910P using Tapatalk |
02-16-2017, 10:08 AM | #64 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Xtra Speed axle
Looks awesome!!! Thanks for the pics
02-16-2017, 04:14 PM | #65 |
Rock Stacker Join Date: Jan 2017 Location: On RCC Studying
| Re: Xtra Speed axle
Where did you get them for $28 for the pair? I just ordered a set from amazon for 50 shipped. I have a set of currie's and was getting ready to order another set until I came across this thread. Can't beat the price for a second or 3rd build.
02-16-2017, 05:39 PM | #66 |
| Re: Xtra Speed axle
Got to test the strength today. Hit a rock with enough speed and force to break the case of my Savox 1230, axle shrugged it off. Sent from my SM-N910P using Tapatalk |
02-17-2017, 12:42 PM | #67 |
Rock Stacker Join Date: Mar 2009 Location: N/A
| Re: Xtra Speed axle
I gotta say, this was a good buy. I had to scrape the paint for the inside pinion bearing. The outside pinion bearing fits a little loose, but a tiny bit of blue locktite fixes the looseness, green lock tight would work best though. Shim the diffs and she good to go.
02-17-2017, 02:33 PM | #68 |
Pebble Pounder Join Date: Jun 2013 Location: Espoo, Finland
| Re: Xtra Speed axle
Just ordered these myself. Pretty crazy, that the only Axial-branded parts I ordered for the "Axial AR44 axle" were the 2,6mm x 12mm screws and the locker/pinion bearings All else was Xtra Speed and SSD. Can the locker be shimmed, or only the pinion gear? Should I by default shim it so that it is as close to the big bearing? Or as close to the spur gear as long as it still runs smoothly? |
02-18-2017, 02:38 PM | #69 |
Quarry Creeper Join Date: Nov 2012 Location: Wapella
| Re: Xtra Speed axle
Ordered mine on the 12th and they got delivered this morning. Hope to get them installed Monday. Any tips besides scraping the paint for the bearing ?
02-20-2017, 02:08 AM | #70 |
Quarry Creeper Join Date: Nov 2016 Location: Surrey
| Re: Xtra Speed axle |
02-20-2017, 08:21 AM | #71 |
Pebble Pounder Join Date: Dec 2012 Location: Delaware
| Re: Xtra Speed axle
How are these holding up for everyone? I'm interested if they would last being smashed into rocks.
02-21-2017, 10:47 PM | #72 |
Newbie Join Date: Aug 2011 Location: Corbin
| Re: Xtra Speed axle
Well, I ordered mine after seeing some of your all's comments about them. I went ahead and ordered the xtra speed steel driveshafts for the rear and their cvd shafts for the front. Also picked up a set of Samix aluminum steering knuckles as well. Can't wait for them to get here.
02-21-2017, 11:05 PM | #73 |
02-22-2017, 06:43 AM | #74 |
Pebble Pounder Join Date: Dec 2016 Location: Puerto Rico
02-22-2017, 06:45 AM | #75 |
| Re: Xtra Speed axle
Cool. Anyone have any experience with these Xtra speed front and rear driveshafts? |
02-22-2017, 07:21 AM | #76 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
| Re: Xtra Speed axle
Not driveshafts, Axle shafts
02-22-2017, 10:34 AM | #77 |
02-22-2017, 07:09 PM | #78 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
02-26-2017, 03:34 PM | #79 |
Quarry Creeper Join Date: Aug 2008 Location: Sweden
| Re: Xtra Speed axle
Any pics with SSD parts on these axles? Skickat från min iPhone med Tapatalk |
02-27-2017, 07:09 PM | #80 | |
| Re: Xtra Speed axle Quote:
Yes, shim both the locker and pinion. On mines with the stock locker and ring, I put a .2mm on the pinion, and .4mm on the locker. The locker was sliding left to right. Shims should go between bearings and locker/ring. Sent from my iPhone using Tapatalk | |
Xtra Speed axle - Similar Threads | ||||
Xtra speed "steel" SCX10 axle housing for everest 10 | Smokin' Joe | Redcat Crawlers | 9 | 12-24-2017 11:53 AM |
Xtra speed axle shafts on wraith? | dannyboyjdc | Newbie General | 1 | 11-21-2016 07:09 AM |
Xtra speed aluminium axle | Johan_Eriksson | Axial SCX-10 | 0 | 11-12-2016 01:37 PM |
Anybody see this yet, xtra speed sentinel | dubyas1989 | General Crawlers | 1 | 07-29-2016 09:41 AM |
xtra speed rc | roughneck | General Crawlers | 6 | 04-06-2014 09:17 PM |
