01-08-2017, 10:18 AM | #21 |
Rock Stacker Join Date: Sep 2012 Location: Waterloo
| Re: SCX10-II - Winning is hard.
Wow, that front clip looks awesome! I have the grille so far on my hilux body and love how it looks. Do you happen to remember what sliders you chose for that body? Scalerfab doesn't list them as an option. Sent from my Nexus 6P using Tapatalk |
01-08-2017, 03:06 PM | #22 | ||||
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: SCX10-II - Winning is hard. Happy to help! Quote:
LINKY I've intentionally left these raw, so they'll rust over time to match the wrap. | ||||
01-08-2017, 03:50 PM | #23 | |
| Re: SCX10-II - Winning is hard. Quote:
Sent from my Nexus 6P using Tapatalk | |
01-11-2017, 03:57 PM | #24 |
Rock Crawler Join Date: Jun 2009 Location: UK
Have you added any stick on weights to the wheels? And if so, did you trim the inner foams? Thanks.
01-15-2017, 03:43 PM | #25 | |
I did not add any weight to the wheels, nor did I trim the foams. I like to see how things work without modifying first, so I can set a true benchmark of performance. | |
01-22-2017, 03:48 PM | #26 |
Some updates. My Vanquish parts arrived. Pretty amazing to see that there's very little difference between the prototypes and production axles. Save for the threaded inserts for the front axle and the lasered logo, they're essentially the same. Amazing machine work. Here's a breakdown of the assembly for those that haven't done it yet. I started by removing the stock locker and updating to the Vanquish part. I've yet to have a failure on the stock ones, but heck, for the low price these are offered at, why not? Blue Loctite should be used EVERYWHERE, except the diff covers, FYI, including these little screws holding the ring gear to the locker. Put original pinion gear and original bearings back into housing. Add the bearing holders to either side of the ring gear locker assembly and plop into place in the new housing. Screw this down and LOCTITE AGAIN. Do not overtighten. I had a set of LockedUp RC rear shafts handy, so I've opted to replace the stock ones. They look strong. Everything back together. Screw on the endcaps and remember the bearings beforehand. Did I mention Loctite? Red Diff covers are back in style. And installed back on the truck. Perfection! Vanquish includes all the hardware required for the rear to be put back in place. For the front, the only differences are as follows: Add the threaded collars before putting the shafts back in. Much easier to do beforehand. This spacer is included. Also, check the steering knuckles. Lots of detail and effort went into making these, they're awesome, and realistic. Keep in mind Vanquish does not include the hardware for re-attaching them to the axle - keep those from your old plastic axles. And here's the front reinstalled on the truck. Very, very happy with the tolerances, machining, and looks of these new Curries. I knew they were going to be bulletproof, after all the abuse I gave the prototypes. Hats off to Vanquish! One other thing, I've noticed that there's a lot of inherent flex built into the rear shock towers. My simple, parts bin solution is to take a short Axial link and screw it into the open holes. Reduces flex by 100%. |
01-22-2017, 04:22 PM | #27 |
RCC Addict Join Date: Sep 2014 Location: Alberta
Looking great. I wish I could bring myself to buy a set of those Curries, they look awesome. Nice fix on the rear shock tower too - I haven't got around to it yet but was planning on doing this same thing. The Ascender has them and when I compared that chassis (that I sold) to the new SCX2 I was shocked at how flimsy the SCX2 was. The Ascender chassis is phenomenal, this little fix should close the gap though! Sent from my iPhone using Tapatalk |
01-22-2017, 04:25 PM | #28 |
This shot... is money |
01-22-2017, 04:38 PM | #29 |
Newbie Join Date: Dec 2009 Location: salina
Really nice build, just ordered that same set of axle's and can't wait to get mine after seeing your's, can't wait to see your's done.
01-22-2017, 04:55 PM | #30 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
I have snapped around 7 sets of those little 2x8 bolts that hold the ring gear to the locker. If I would have used loctite, I would not have been able to extract the the bolt. It looks like the holes do not go through the vanquish locker, so would already be a pita to extract. Would suck to have to replace the locker if you snap those 3 little bolts. Sent from my SM-N910P using Tapatalk |
01-22-2017, 05:31 PM | #31 | |
01-22-2017, 05:32 PM | #32 |
Those didn't last either. Sent from my SM-N910P using Tapatalk |
01-22-2017, 05:46 PM | #33 |
| Re: SCX10-II - Winning is hard. |
01-22-2017, 05:49 PM | #34 |
Tried both tight and snug. Even downsized my motor, loosened my slipper and nearly turned my drag brake off. Sent from my SM-N910P using Tapatalk |
01-22-2017, 05:56 PM | #35 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
As usual you have given a very precise review of a wonderful product. And after seeing that red cover I'm either buying a set for my black curries or painting my black ones. Awesome build.
01-23-2017, 08:01 AM | #36 | ||||||
You can say that again! | ||||||
01-23-2017, 09:30 AM | #37 |
do you by chance have a good shot at the winch line routing? Thanks! |
01-23-2017, 10:14 AM | #38 | |
Rock Stacker Join Date: Dec 2016 Location: Norway
01-23-2017, 10:35 AM | #39 |
I don't think I have. I am just going to replace with a one piece ring/spool. Didn't mean to derail, back to our sponsor! Sent from my SM-N910P using Tapatalk |
01-23-2017, 10:44 AM | #40 |
Rock Crawler Join Date: May 2013 Location: Uniontown
I would think the lack of loctite is to blame as it would allow the screws to move and potentially sheer. I've been running my first set of internals on 4s, 35t Torquemaster since July on a 9lbs. C1-2 rig. Including a full pull at a TTC. Back to where we should be, I'm loving this build so far, and I don't even like Toyotas, obviously, lol. Sent from my XT1585 using Tapatalk |
SCX10-II - Winning is hard. - Similar Threads | ||||
Winning! | ittybitty | South Carolina | 6 | 11-14-2012 10:28 PM |
Who's Winning | THnCS | Past RCCA qualifiers | 50 | 07-21-2009 03:03 PM |
