10-06-2019, 12:35 AM | #1 |
Newbie Join Date: Feb 2019 Location: united states
| First Time SCX10 II build
[IMG]44C0276A-1FDA-4E4A-965F-A3E65C177FA9 by luis diaz, on Flickr[/IMG][IMG][IMG]4419BB4B-4A36-4642-9512-70C533FB768E by luis diaz, on Flickr[/IMG][/IMG][IMG]65047AF1-AF98-4621-934A-5A147D40CBFD by luis diaz, on Flickr[/IMG]Luis here. Just started to work on my first rock crawler. This is my entry vehicle going into the hobby. I like the idea of building the whole kit instead of a ready to run rig. But that’s just me! Anyways this is what I’m starting with. Just soldered new bullet plugs into the motor connections and a deans plug to the esc. I honestly felt like I was sort of paying too much for all this stuff, after all I thought, it was just a scale car. After receiving just the esc I seriously fell in love with just how good the quality was. And than after receiving more components, they kept leaving me in awe with the quality. Now I’m thinking “jeez if I tried to save money and got amazing quality stuff, imagine what else is out there!”. Anyways, I plan on making my own from brush bar, and maybe a light cage for the cab of the Comanche. Just some quick shots of what I’ve gotten so far! (I’m waiting on the rest of the stuff to be shipped!) Last edited by luisfdt; 10-06-2019 at 05:18 PM. Reason: Need to add pics |
10-06-2019, 05:36 PM | #2 |
| Re: First Time SCX10 II build
I just saw your rig! Looks good and funny thing is that I’m actually making a Comanche as well. I got the i hora hard body kit. Really good quality, but the instructions are shit haha.
10-06-2019, 09:12 PM | #3 |
Just got in my wheels. Injora beadlock rims and some budget tires.[IMG]0377CA48-C07C-4876-AA2E-B8DF2D7755E2 by luis diaz, on Flickr[/IMG]
10-06-2019, 11:33 PM | #4 |
So after about 2 hours of trying to figure out why the wheel beads were slipping off the rims when I tightened them, I figured the proper way and now they are mounted!, now I only wish I would off thought about painting the back piec behind the actual face of the rim. Oh well! Here’s a moc up![IMG][IMG]DBBB6E15-AF63-48A5-93DB-0F99013A7953 by luis diaz, on Flickr[/IMG][/IMG][IMG]B9E84FF1-66B8-4854-BE6A-59D7CB45D546 by luis diaz, on Flickr[/IMG]
10-08-2019, 11:16 PM | #5 |
So I just finished building the kit a couple hours ago. I have to say, axial has made me love the hobby. The only thing I can complain is 1, there was a piece missing in my kit. A shaft. I was able to go to work and machine my own though (I am a machinist by trade). 2, I wish there was less threading of plastic parts. Basically ALL bolts go into unthreaded plastic and it’s obviously going to be a problem with time. I might even go in and do a bolt and nut conversion to all bolts (or mainly the ones that will be loosened and fastened often) or simply upgrade to metal parts. But than that basically means building a whole other kit. Overall I am happy with the quality worksmanship that has gone in the kit. I came across only 1 problem, and that was that my servo was either too short or too long and it would get in the way of the A brace on the right shock tower. The other problem was the cheap tires I bought. The car would sort of turn and hop or do a sort of step turn, I did some tease arch and found Its because the foams are too small for the tires. Even my girlfriend said “those look flat!”. But that’s my fault. Just 2 hours into crawling my little hill and I already broke a mirror! Haha I haven’t even painted the body and I’m already scratching it! But that’s how much I was having, so that’s ok! Major upgrade that I feel need to be done ASAP are, shocks and transmission case. [IMG]BB9218F2-B57A-4059-B05B-D8386B3A06FE by luis diaz, on Flickr[/IMG] |
10-09-2019, 08:12 AM | #6 |
I keep calling it a Comanche to help me feel better for being so dumb and not noticing it’s just a Cherokee in the first place! Hahaha
10-09-2019, 03:02 PM | #7 | |
| Re: First Time SCX10 II build Quote:
As for tires/foams, they foam should not necessarily fill the tire, depends on foam type, hardness, single stage, two stage, etc. By looking at the tires I knew they would not be great performers, ime better to buy name brand tires ymmv. Are the beadlocks plastic or metal? I like my 1.9 wheels to weigh about 76g per wheel for good performance but not too heavy. | |
10-09-2019, 04:11 PM | #8 |
Definitely need better wheels. I have my eye on some from rc4wd I’ll be purchasing later this week. And yes the bead locks are 3piece Metal! They weigh a good amount, I don’t know the exact number. Also, I cleaned up the wiring a bit, the servo I purchased claimed to be water proof but I still opened it and put marine grease on the river seals. I used the provided box with the rubber passage for the wires. I cut the esc and servo wires than put them through the rubber along with some marine grease than soldered them back up. Pretty easy process. Marine grease is awesome! The truck was pretty dirty so to test the water resistance I drenched it very thoroughly and it worked just fine! AWESOME! Now time to get some scratches off the body and get it ready for primer. But first, time to build a spray booth.[IMG]A5D2C893-9FF6-452B-A838-EA6E49F02E25 by luis diaz, on Flickr[/IMG] |
10-09-2019, 05:39 PM | #9 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
| Re: First Time SCX10 II build Nicely done. How about calling it a Comanchero...
10-10-2019, 02:48 PM | #10 |
| Re: First Time SCX10 II build |
10-10-2019, 02:54 PM | #11 |
Glad I could help. I came across the pic awhile ago and thought, I should save it cause it's so odd and cool at the same time.
10-10-2019, 06:06 PM | #12 |
I have now come to a stop, front axle is hopping at about 1/2 throttle and full turn. I’m doing research on what it could be now. Might pull the axle apart and rebuild
10-11-2019, 07:38 AM | #13 |
I'm kinda nuts when it comes to wheels and tires. IMO, wheels can determine the overall look of a vehicle, and can enhance even the color. That being said...this is what I would do... These are 1.7's but serve 2 purposes, keeps the same height as your Grabber tires and maintains the 5 lug wheels that Cherokee's come with. Can't wait to see it painted. You can use automotive touch up paint on hard bodies too, giving a multitude of color options. |
10-11-2019, 10:00 AM | #14 | |
As to the paint I was thinking of doing something of a barn truck like I did to this ol Chevy, but I figured the whole “barn truck” fits more to the chevys and fords. So I’m going to do something sporty looking for the Comanchero! [IMG]EDA12303-2A0D-4926-A009-25D6F8576707 by luis diaz, on Flickr[/IMG] | |
10-11-2019, 02:58 PM | #15 |
After a long day at work, I got started on the painting process. First used some Tamiya primer than after it settled for a couple hours I used Tamiya ts-58 pearl light blue, Ive let it sit for about 2 hours now and should be getting ready to mask! Yes there is still more color to come! I need to head down to Walmart and get some bed liner spray. I like the texture it leaves. As long as the wheel wells, I made one but it was..funny looking haha. Anyways here some progress pics.[IMG]55DB3ECB-80F0-4E9A-83A4-F86C0CF85449 by luis diaz, on Flickr[/IMG][/QUOTE][IMG][IMG]DC0C06D1-25E6-47C9-B536-BF3565566AAB by luis diaz, on Flickr[/IMG][/IMG]
10-11-2019, 09:54 PM | #16 |
So I’ve been working hard today! Here’s some progress! [IMG]83414C27-92FF-4FAE-BEAE-A6A20EB5E4F5 by luis diaz, on Flickr[/IMG]
10-12-2019, 06:21 PM | #17 |
Just finished the main part of painting. I’m really happy with how it came out and the overall look. Now time to figure wether I’m going to be fabricating my own bumper or buy one that I like. Anyways, here are some progress pictures![IMG]3563BE56-E276-42F9-95AF-2A70621923DD by luis diaz, on Flickr[/IMG][IMG]0E2EC58A-2269-405B-8320-34C3888B3AC9 by luis diaz, on Flickr[/IMG]
10-13-2019, 10:21 AM | #18 |
Looks great! Forgot you had this going in two different sections. It needs some meats to fill out the flares...these would look sweet... |
10-15-2019, 08:04 PM | #19 |
| Re: First Time SCX10 II build YES! I saw those on their website and really liked them. I really like the bead locks I have installed now but they are 26mm (1.69inc) will they mount on them?
10-15-2019, 08:06 PM | #20 |
Did some fender well work today using styrene, I will do them again eventually since I want to sort of Tun the whole interior, as it is now there is still a gap between the body and frame, I’m hoping some side bumpers will take care of most of that, but anyways even with some haggard wells, it makes the truck look a lot better![IMG]EC4C8A74-37EA-48AE-BD85-3E3A6A72BE07 by luis diaz, on Flickr[/IMG]
First Time SCX10 II build - Similar Threads | ||||
The time only build | CM9000 | Team Losi Comp Crawler | 18 | 02-20-2019 09:27 PM |
scx10 first time build | luisfdt | Newbie General | 11 | 02-13-2019 01:11 PM |
Finished most of my build... Time for a rundown. SCX10/Hilux | tommyargh | Axial SCX-10 | 14 | 07-24-2013 06:24 PM |
Figure its time to post up my JK SCX10 Build | DaveFL | Axial SCX-10 | 2 | 06-21-2013 08:34 AM |
First time build | mavicracer | Tamiya Clod Buster | 4 | 03-13-2007 01:41 PM |
