Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 III
Thread: Best Battery Choice
Old 04-04-2021, 06:33 PM   #1
Default Best Battery Choice
Currently running a 3s 5000mah in the stock location on the drivers side floorboard. I want to change to something more performance oriented and I don't mind packing two or three smaller batteries to get the runtime. What are you guys running and in which location? I don't run the interior or cage if that makes a difference. Thanks
2wheeler is offline   Reply With Quote
Old 04-08-2021, 12:39 AM   #2
Default Re: Best Battery Choice
Why don’t you put the battery in the rear tray?
BansheeRider is offline   Reply With Quote
Old 04-08-2021, 08:13 PM   #3
I could try that... I also bought a couple of 1,300mah packs to try
Old 04-09-2021, 10:45 AM   #4
I have been running 1300mah & 2200mah 3S Spektrums lately in my 10.3.
Phyro is offline   Reply With Quote
Old 04-09-2021, 12:45 PM   #5
I'm not running a 10.3 but all of my scaler/crawler rigs will only ever see 2200mAh batteries. (3S)
I strongly dislike the weight penalty of anything bigger.
QuesoDelDiablo is offline   Reply With Quote
Old 04-09-2021, 02:37 PM   #6
I am currently running 2S 80C 5200 MAH Hoovo from amazon. if I recall they were $33 for two of them. I like the run time of a larger MAH battery.
I choose not to run a larger cell battery, IMHO more power = more broken parts. I have been out three times and each time I go the fully upgraded $1500 rigs are constantly breaking!
Den72 is offline   Reply With Quote
Old 04-09-2021, 04:42 PM   #7
Hey Phyro, what position do you run your battery in? The driver floorboard or across the frame behind the trans?
I agree, the long run times are great but it kills my performance. I'm willing to do battery swaps more frequently for the performance gains.
Old 04-09-2021, 07:40 PM   #8
I ended up with a Tekin RX4 in mine, so wasn’t able to put the ESC in the normal location. Got the RX4 in the side tray, and using the rear tray for batteries.
Best Battery Choice - Similar Threads
Battery Choice msly Newbie General 20 05-10-2016 12:05 PM
Battery choice mini4wd Formula Offroad 33 02-06-2013 10:16 PM
Battery choice BigDHD09 Electronics 2 02-03-2013 07:36 PM
Battery choice Subytuner Losi Mini-Rock Crawler 5 09-18-2012 08:05 PM
battery choice karrfab Axial Wraith 9 06-19-2011 09:02 AM
