09-30-2011, 02:01 PM | #21 |
Rock Crawler Join Date: Jan 2007 Location: UK
Update: I have bought new rear shafts and they are the same i.e wrong
09-30-2011, 04:12 PM | #22 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
I've got the same problem with my Kit Wraith, I just ended up drilling the recess on the back of the ring gear a little deeper until everything fit like it's supposed to.
10-02-2011, 08:33 PM | #23 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
My kit wraith short side is doing the same thing... I am using a felsenfest locker and with the other axle not even in there the short side still sticks out to far. So it's not like its getting stuck on the other axle it just won't seat far enough in the locker. Axle or housing is out! I'll have to email axial! Any other suggestions? Wrecker... what recess? where the four bolts go into the locker? |
10-03-2011, 03:24 AM | #24 |
Newbie Join Date: Dec 2004
I had the same problem, everything in reverse and after getting everything right the axle wouldn't close. I ended up machining about 1 mm out of the ringgear so the axle would sit a little deeper. Works great! |
10-03-2011, 06:24 AM | #25 | |
10-03-2011, 08:11 AM | #26 |
Cool thx. I figured it was the bearing seat flange. I'll get a hold of axial and see what they'll do.
10-03-2011, 07:44 PM | #27 |
Hell's Gnome Join Date: Jun 2006 Location: I'm mean because you're stupid.
Just started my build and came up against the same POS design on the short rear shaft as others have. Just like the first pictures. I'm tired and pissed off that I have to drill shit out for it to work. This had better be the only problem I find and this is one to many. |
10-03-2011, 08:08 PM | #28 |
I emailed axial and their R&D department is on it. I'll wait till their fix is sent out. I'm not drilling anything. But then again I got the time to wait.
10-04-2011, 03:51 AM | #29 |
Newbie Join Date: Dec 2007 Location: outlands
same here with the kit version. I just made new holes on the axle housing to accommodate for the extra length. I'll probably dremel out the diff gear like everyone else later.
10-04-2011, 04:54 AM | #30 |
10-04-2011, 07:07 AM | #31 |
My reply from Axial Hi Mark. Thanks for contacting Axial Racing. I am sorry to hear you are having a problem with your new Wraith kit. I will pass this information to R&D and production in a effort for better quality control. I did build this kit over the weekend and found the tolerances to be tight but it did go on a didn't affect the performance. I will follow up with you after hearing back from R&D. Please call or email anytime you have questions or concerns. Thanks again Scott. Sincerely, Scott Kerkes |
10-04-2011, 11:47 AM | #32 | |
10-05-2011, 10:52 AM | #33 | |
Very true, I could feel the teeth mesh when I tried to turn it and it was very bound up. I may figure this out later, but why on earth would anyone mount the steering linkage to the bottom of the metal knuckle tabs? Mounting it to the top seems like a no brainer. I may find out shortly. | |
10-05-2011, 11:54 AM | #34 |
So, this is only an issue with aftermarket lockers? Has an aftermarket locker been found that does not have this issue? |
10-05-2011, 12:22 PM | #35 |
10-05-2011, 12:26 PM | #36 |
10-05-2011, 12:31 PM | #37 | |
It won't go away unless you change the shaft or make adjustments elsewhere. | |
10-05-2011, 12:37 PM | #38 | |
I'm about to start an Axial Wraith axle build. I was going to upgrade both lockers. After reading this, I'm thinking that I should use stock Axial lockers in the rear. Am I correct in assuming that there is not an after market rear locker that will work with the defective Axial rear axle short shaft? | |
10-05-2011, 01:52 PM | #39 |
I am having the issue with all stock parts.
10-05-2011, 02:17 PM | #40 |
No matter what locker it's an issue. It's the axle. I tried stock and after market. Both had the same problem. It's beyond tight. Mine will not go together at all!
