10-17-2011, 04:36 PM | #41 | |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
10-17-2011, 04:37 PM | #42 | |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
its like grabbing a wrench with oil on your hand, add something to help the grip, and your good to go. Edit: yep you got it! Never understood why they say put it on the lockers, mine still has plenty of play lol for shits and giggles, here my wraith: ill be watching for insperation! Last edited by OntarioCrawler; 10-17-2011 at 04:40 PM. | |
10-17-2011, 04:42 PM | #43 | |
10-17-2011, 04:50 PM | #44 | |
And thanks, its mainly stock, though i finally got it running decently. if i find anything ill be sure to post up. | |
10-17-2011, 06:30 PM | #45 | |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
Well, i wouldnt want to glue tires to those expensive wheels, and unless you do something like make a spacer to wedge in between your ring and tire to clamp the tire more firmly, i dont see another solution besides removing some material from the face of the rim. It wont be seen, and its an easy fix, and it will remain just as easy to mount the tires. I dont know of anyone that makes a shim to clamp the tire under a ring harder, i imagine it would be a PITA to mount a tire with a whacky shim in there. If they are already used, there is no sending them back to VP (i dont think so anyways), another solution is to sell those wheels and try another set but you will just loose money. Easiest fix=sand them down. Its up to you, do what you want, i was just trying to offer a solution to the problem you were looking for a solution for. Maybe use a piece of another tire to cut a ring (or from and use that to pinch the tire better, but if it was me, i would sand them down | |
10-17-2011, 07:24 PM | #46 |
Oh never glue them. thats why loctite. its designed to harden and secure things. Beats grinding them down.
10-18-2011, 11:04 PM | #47 |
32p Spur ive been using, No real issues - had a rock jump up and take a tooth off - finished off 3 packs with a missing tooth. Didn't sound pretty, but it did it - Still a good spare! TowerHobbies.com | DTXC9397 DuraTrax Spur Gear 32P 56T Nitro Evader BX Paired up with one of these (5mm shaft on Pro4) http://www3.towerhobbies.com/cgi-bin...?&I=LXBAWE&P=7 |
10-19-2011, 07:35 AM | #48 | |
10-19-2011, 08:31 AM | #49 |
10-19-2011, 09:01 AM | #50 |
Good to know. Though, if you setup your gear lash correct you shouldn't ever have a problem. ive run 2s lipo's and a 55 turn venom through my scx10 and never had the gears skip a tooth.
10-19-2011, 09:33 AM | #51 | |
3s lipo and brushless or 3s lipo and a 13t Crawlmaster are going to put much more abuse on the drivetrain. Let alone when we bump up to 4 or 6s lipo. Also 5.5" tall sticky tires make for more resistance. | |
10-19-2011, 11:23 AM | #52 | |
Speaking of failing drive-train parts, Rear ring gear's got teeth bout as sharp as a shark - so, time to upgrade. Nice to see the through pin! Axial HEAVY DUTY BEVEL GEAR SET (Yes, this is stock ratio) | |
10-19-2011, 11:51 AM | #53 |
So the new HD gears are helical cut now too?! Thats cool to see.
10-19-2011, 11:52 AM | #54 |
10-19-2011, 11:53 AM | #55 |
Pebble Pounder Join Date: Dec 2006 Location: San Diego
Nice gears Ray |
10-19-2011, 12:20 PM | #56 |
Alright, so from a novice when it comes to power, and a budget around $150, i have a 25C 2s lipo that works for me, what motor and esc would you recomend. I love SLOW crawling, with tons of control, but its nice to have a blip of speed. I have a 55t venom and a 55t axial now, but im fine with getting something if it give me what i need. Also, i should have gotten the 7955 servo, im kicking myself for getting a 5645MG digital. I found most standard 55T dont like 2s power, and i was looking at brushless, but i always thought a low turn brushless was built for speed, not torque. Any ideas? |
10-19-2011, 12:32 PM | #57 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
Your wraith is the bomb diezel! Ill be running mmp/13.5t, 13 or 14mm rotor on 3s. I guess ill need to run 32 pitch then! I liked 87/16 in my scx10, had good low and top end. Whats an all around good 32pitch spur and pinion #? 56/14 or 58/14? may have to try that 4 pole motor also Last edited by Cableman; 10-19-2011 at 12:34 PM. |
10-19-2011, 12:39 PM | #58 |
I like 56/14, personally. Fit's my driving style. Just that little bit of extra wheelspeed. Time to get down to business. Josh... My bank account hate's you. |
10-19-2011, 12:42 PM | #59 |
10-19-2011, 12:47 PM | #60 | |
That servo kicks the shit out of EVERY SERVO I'VE EVER USED. I run 60/15 which is the same ratio but won't fit in the spur cover. A little better tooth contact patch though. I like the ratio, works great for me. | |
