02-28-2012, 06:05 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Taller tires
Anyone knows what tire is available that's taller than the tipical 5.5" tall, 2.2" tires? i'm tired of dragging the axles over every little obstacle, i like to know if there's a tire available in 6" or 6.5" in diameter
02-28-2012, 06:07 PM | #2 |
Pebble Pounder Join Date: Aug 2011 Location: schererville
RC4WD 2.2 IROKS. Sent from my Motorola Electrify using Tapatalk |
02-28-2012, 07:04 PM | #3 |
Rock Stacker Join Date: Apr 2009 Location: topeka
| Re: Taller tires
baja claws ttc are 5.75 and RC4WD iroks are also 5.75 about the only two
02-28-2012, 07:43 PM | #4 |
| Re: Taller tires That's bad. Maybe somebody makes a portal axle for the Wraith in the near future |
02-28-2012, 10:44 PM | #5 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
| Re: Taller tires
Lol! Maybe try switching to 5" tires for a while so u can learn to appreciate 5.5". The stock tires are huge.
02-28-2012, 11:33 PM | #6 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
| Re: Taller tires
maybe you should try some different lines. i run a 1.9 rig and only really hit the pumpkin when i cant see rocks in ditches.
02-29-2012, 12:32 AM | #7 |
RCC Addict Join Date: Oct 2007 Location: gervais
02-29-2012, 01:21 AM | #8 |
Quarry Creeper Join Date: May 2008 Location: malvern
| Re: Taller tires
This is the new Irock next to a pro-line super swamper and they are huge. |
02-29-2012, 04:16 AM | #9 |
| Re: Taller tires
Swampers may be huge on a scx10 but on a Wraith they look normal. Hopefully somebody comes out with a tire of 6" or more
02-29-2012, 07:30 AM | #10 |
Newbie Join Date: Dec 2004 Location: Phoenix, AZ
| Re: Taller tires
Sounds like you just need more practice. Larger tires will help to a point but at the end of the day it's just like 1:1, you pick the wrong line and your stuck.
02-29-2012, 07:55 AM | #11 |
| Re: Taller tires
also if you want a bigger tire you could go to a 3.2" wheel and modify the hex to fit the 12mm on the wraith. i think smaller tires are more fun. i use the 4.5" proline hammers that came stock on my ax10, just added lots of weight. i go everywhere and do everything that the 5.5 guys do.
02-29-2012, 11:38 AM | #12 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| Re: Taller tires -_- 6.5" Axial Ripsaw Cut N Shuts By Crawler Innovations -_- Here ya go. Not sure on cost or lead time, but they dont come muxh bigger. |
02-29-2012, 01:58 PM | #13 |
| Re: Taller tires
Nice, but that looks like a custom ($$) setup, hopefully one of the tire manufacturers will realize that we need a taller tire
02-29-2012, 02:24 PM | #14 |
Alright so we just gave you every choice available from stock size to custom and your still not satisfied? The chances of getting a production 6+ inch tire is fairly small, if your going to be picky then try 40 series or like what has been said already, 3.8
02-29-2012, 02:27 PM | #15 |
| X2 on this, if your needing such a giant tire, then you should really learn to slow it up a bit and practice because there will be a point when the tire is just too big and your not actually crawling anymore.
02-29-2012, 02:56 PM | #16 |
| Re: Taller tires I already have a savage Flux, i can try those tires to see how they fit but need to find adapters first
02-29-2012, 03:45 PM | #17 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
| Re: Taller tires |
02-29-2012, 04:22 PM | #18 |
| Re: Taller tires |
02-29-2012, 04:53 PM | #19 |
| Re: Taller tires i see most people on here doing fine with what they have. a day at the park - YouTube zoo run - YouTube in both of those videos the little blue ford is mine. it is running one 1.9 rock creepers. those are under 4 inch tires. and you only see me get stuck on the pumpkin twice. and both times i easily corrected. by changing up my line. as people on here are saying you just need to practice. |
02-29-2012, 04:54 PM | #20 |
Taller tires - Similar Threads | ||||
Standard foams for taller tires..(2.2) | Biscuit | Tires and Wheels | 5 | 04-07-2009 07:00 PM |
Taller 2.2 tires .... thoughts? | Locked Up | Tires and Wheels | 15 | 10-26-2008 09:35 PM |
making shorter tires taller | yukon635 | Tires and Wheels | 1 | 06-01-2007 08:46 PM |
Need taller tires | fireexplorer19 | General Crawlers | 19 | 07-16-2006 09:20 PM |
Taller tires for free!!!! | SR5Dave | Tamiya Clod Buster | 2 | 04-25-2004 09:29 PM |
