05-03-2012, 02:52 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
| Wobbly Shaft...???
The last time out my slipper clutch was slipping a bit too much, so I took it apart to adjust the spring and noticed that the pinion gear looks slightly cockeyed against the spur gear. So I loosened the motor mount bolts and spun the spur gear under the magnafying light and this is what I found....it is a bit wobbly. You can see the spur gear along with the slipper clutch oscillate. Is this normal, or if not what would cause this condition??? Wobbly Shaft..?? - YouTube Last edited by Land Crab; 05-03-2012 at 02:57 PM. |
05-03-2012, 03:18 PM | #2 |
Pebble Pounder Join Date: Apr 2010 Location: Guam
| Re: Wobbly Shaft...???
I have that exact problem. I think the slipper discs may be bent if not it's the shaft. I just got an extra set to try to troubleshoot it but won't be able to do so till I get off work. Hopefully someone who's fixed this problem could chime in. This just saved me from starting a new thread. |
05-03-2012, 03:51 PM | #3 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
I wonder if one or two of the 3 mounting bolts are just a bit too long and protruding through the slipper plate into the slipper disc? I had to use washers on the bolts to prevent this. I guess different spur manufacturers make them in varying thicknesses.
05-03-2012, 04:22 PM | #4 | |
| Re: Wobbly Shaft...??? Quote:
I took the spur gear off and spun the shaft and slipper plate under the magnafyer and it spins straight as an arrow. So I put the spur and slipper pad back on and it was only when I tightened it down that the wobble happened. So I tried to get the spring as centered as possible (you can see that it is off center in the first video) and once centerd, I can tighten the nut all the way down, then back it off about 1/8 of a turn and it now spins nearly perfect, or about as good as it is gona likely get. I also found a larger OD washer to put between the spring and the spur/slipper to theoretically more evenly distribute the load. http://www.youtube.com/watch?v=Bu3Z-RP6yoUi Last edited by Land Crab; 05-03-2012 at 04:54 PM. | |
05-03-2012, 05:00 PM | #5 |
OK, that makes sense. I've noticed the spring is not always centered on the shaft and I've had to re-center it on a couple of trucks. It would be better if inner diameter of the spring was close to the shaft size. Glad you got it sorted. |
Wobbly Shaft...??? - Similar Threads | ||||
Need more torque, wobbly wheels and pinion spacing | optikalillushun | HPI Wheely King | 11 | 11-12-2011 04:03 AM |
R1 wobbly front wheels | adrians3109 | G-Made Crawlers | 19 | 08-19-2011 03:44 PM |
wobbly tires | o3_xterra | Newbie General | 5 | 11-12-2009 06:28 PM |
wobbly front wheels? | tim the toolman | Axial AX-10 Scorpion | 6 | 05-26-2008 03:07 PM |
spur wobbly | solomon7 | HPI Wheely King | 9 | 08-25-2007 04:46 AM |
