06-07-2012, 10:29 PM | #1 |
Pebble Pounder Join Date: May 2012 Location: muscatine
| 4WS and bec
I have and successfully run a savox 1283 with a cc bec @6v, ok works great. Tonight i set up a rear steer with a traxxas 2075(temporary) so i figured i would be ok running that servo off my tekin rspro bec. well whenever the tires arent aloud to do what im telling them to i lose all control until the servo is aloud to move into position. i assume its an internal bec issue, if thats the case is it recommended to run two external becs or what? do people run two servos off one bec?
06-07-2012, 10:33 PM | #2 |
| Re: 4WS and bec
You can run 2 off one BEC. See the stickys for diagrams. If you step up to some real big power servos you may need two or a BEC Pro.
06-07-2012, 11:39 PM | #3 |
| Re: 4WS and bec
ooo missed that diagram. i hadn't considered the pro version.for now ill go with a Y harness to distribute the power...im gonna need to figure out where to put all these wires though, starting to get to be a pain.
06-08-2012, 02:19 AM | #4 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
| Re: 4WS and bec |
06-08-2012, 08:08 AM | #5 |
| Re: 4WS and bec |
06-08-2012, 09:53 AM | #6 | |
Pebble Pounder Join Date: Apr 2012 Location: SWE
| Re: 4WS and bec Quote:
CCbec puts out 10amps if all things is optimal. that is input voltage on 5Volts = Max 10Amps output 12Volts (3s-lipo) = 7Amps 24Volts (6s-lipo) = 5Amps over 20kg x 2 servos need 2 becs or pro ver. Buy 2 normal CCbec. lets say you 1 day will uninstall the rearsteer and keep your high POWA servo then your stuck with pro ver. on 1 servo. then truck nr2 needs a new bec for that powa servo. And i dont advise any1 to run 10amps thru a servocable thats my op. | |
4WS and bec - Similar Threads | ||||
Wiring 4WS to BEC | wojpa | Electronics | 10 | 08-25-2013 03:03 PM |
4WS and BEC | K3ITH | Axial Wraith | 4 | 04-10-2012 02:08 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
4WS XTM X-Crawler - Please verify my dual ESC + BEC wiring | HairNutz | Electronics | 1 | 06-18-2009 12:13 AM |
