Re: Terra-Wraith I like those output shafts do you have some pics of them in the housings? |
Re: Terra-Wraith Quote:
Re: Terra-Wraith 1 Attachment(s) If this shit breaks, I'm finding a new hobby :ror: |
Re: Terra-Wraith now with MIP mod 2 Attachment(s) Got my new shafts today and they fit perfectly, no trimming or other mods needed :) |
Re: Terra-Wraith now with MIP mod Looks good. Now put the shocks on. :lol: |
Re: Terra-Wraith now with MIP mod 1 Attachment(s) Quote:
Done :flipoff: JIA, your such a negative nancy :ror: Its not what I really wanted to do but it works and everything is nice and smooth. I just use long screws that go through to the back of the arms. I thought the arms may flex too much but its not even an issue. I wanted to use some internal spring shocks but the only ones available look cheesy and the crawler spring rates would be way too soft. |
Re: Terra-Wraith now with MIP mod That's the only thing I could think of to be able to run the PowerStrokes with those in place. Did you space the top shock mount at all? |
Re: Terra-Wraith now with MIP mod Quote:
Now I need to start tearing the rear apart. |
Re: Terra-Wraith now with MIP mod Well send me the front end so I can build a custom chassis off the Terra front end. I need to buy one of these kits - so many ideas........ |
Re: Terra-Wraith now with MIP mod 2 Attachment(s) Done!! Ready for testing!! |
Re: Terra-Wraith now with MIP mod 2 Attachment(s) Couple more :mrgreen: |
Re: Terra-Wraith now with MIP mod Little Update: Well, I put some time on the mod and overall I'm happy with it. I had it bound up every which way in the rocks and no breakage, Thank god. After 3 2200 packs I did notice that the diff side drive hub on the left rear was a little loose. The set screws backed out some which pisses me off because I cleaned everything with brake cleaner, applied red lock tight and tightened the shit out of em with a high quality driver.... Then let it cure overnight.. So I ordered knurled point set screws from Mcmaster Carr: McMaster-Carr If that doesnt work Ill drill the outputs for traxxas screw pins.. |
Re: Terra-Wraith now with MIP mod I am thoroughly impressed. WOW!!! I can't wait to see this beast in action. Awesome build. Now lets see if we can get that thing "G6 Certified"! "thumbsup" |
And just another update.. For any one wanting to do the MIP mod.. The knurled tip set screws solved the out drive loosening issue.. I had to buy a box of 50 so if anyone wants 8 for their build pm me"thumbsup" |
Re: Terra-Wraith now with MIP mod I like the idea but Im gonna have to see some G6 action to believe it. Think it will be ready by the 10th ? Ru gonna run it? |
I will be rockin the Terra-Wraith "thumbsup" |
Re: Terra-Wraith now with MIP mod 3 Attachment(s) The rig is running perfectly and has not broken after hours of G6 and other random stupidity..:ror: I thought I would post some pics of today's outing.. This thing seems to have so much more traction these days8) |
Re: Terra-Wraith now with MIP mod 3 Attachment(s) More |
Re: Terra-Wraith now with MIP mod 2 Attachment(s) Yup |
