Thread: Vxl with new pinion gear
Old 03-30-2013, 10:50 PM   #1
Default Vxl with new pinion gear
Ok so I'm sure someone is gonna tell me to look threw the wraith gearing and all that BUT! All I need to know is that I'm running the vxl with stock wraith gears and a 20t pinion gear and I'm putting a 24t pinion, how big of a difference is it gonna be? I mainly use it for bashing/hill climbs.
Bogncrawl is offline   Reply With Quote
Old 03-31-2013, 06:10 AM   #2
Default Re: Vxl with new pinion gear
Choosing a motor and ESC for your Wraith - Gearing Added!
There is a ton of info in here. Just doing it before someone does!
isyeskeert is offline   Reply With Quote
Old 03-31-2013, 06:38 AM   #3
Going up 4 teeth could be the difference from running good to overheating. Try it and check temps. Im about 60% done with my wraith and I too will be running the vxl motor. I have the stock ring/pinion gears in the axles and im gonna try 93T spur with a 16T pinion on the motor with a 3s lipo.
Johnnysplits is offline   Reply With Quote
Old 03-31-2013, 09:05 AM   #4
Once I get it back together today I'm gonna test it out a little bit
Old 02-23-2014, 07:09 AM   #5
How did u make out.
pavo87 is offline   Reply With Quote
Vxl with new pinion gear - Similar Threads
Which pinion gear works best with RC4WD Steel spur gear? e32lover HPI Wheely King 8 03-10-2013 06:09 PM
What pinion and spur gear should i run with a traxxas vxl? Stangdude99 Axial SCX-10 0 12-27-2012 11:07 AM
Which spur gear and pinion gear with 35t motor vegas1973 General Crawlers 1 08-19-2012 11:42 AM
summit tranny/vxl pinion? lifted_xj 2.2 Scale Rigs 3 12-30-2010 01:27 AM
summit tranny/vxl pinion? lifted_xj Axial SCX-10 2 12-29-2010 02:05 PM
