06-04-2013, 11:14 PM | #1 |
Newbie Join Date: May 2013 Location: joliet
| point me in the right direction.
I have read as much as I can but can't find what I need answered. So I'm getting out of 2wd mod buggy racing. I'd like to possibly keep my tekin rs and Redline 9.5. Will that even work in a wraith? My struggle is.... rtr wraith and kit. As well as possibly a Bully. Can the rs do dual motors and would they have to be brushed? |
06-05-2013, 06:09 AM | #2 |
Rock Stacker Join Date: Mar 2013 Location: ENGLAND
| Re: point me in the right direction.
I'd have said it will rip it apart unless you beef everything up
06-05-2013, 06:29 AM | #3 |
I would have to say the 9.5t would be ridiculous! It would be fun speed wise but not sure how it would crawl.. I run a 13.5t in mine with all metal beefy drive train with vvd's up front and something started clicking yesterday.. so yeah it may tear a rtr apart pretty quick..
06-05-2013, 12:33 PM | #4 |
Rock Crawler Join Date: May 2012 Location: Upland
That would be fine. Set the can timing anywhere from zero to ten degrees and up the boost in hotwire on the rs. Then you have smooth power at low rpm and increased timing for speed. Should keep the motor cool, too. Sent from my PG86100 with Tapatalk 2 I <3 Tekin |
06-09-2013, 08:06 PM | #5 |
So my roommates scx10 motor died after moving a couple ton of rock to the back yard.... itching to get the party started I swapped in the RS and the 9.5 brushless.... wow. So smooth and plenty of torque. Doubled speed but I don't really care about that. Seems to be holding up well. STill not sure if I wanna spend over 310 on a kit wraith when I can get a moa like a bully or enroute for 60 less. I'm not going to comp it... just want best set up for money. |
06-09-2013, 08:42 PM | #6 |
Do you have a hot wire? Are you in sensored only mode? Sent from my PG86100 with Tapatalk 2 I <3 Tekin |
06-09-2013, 09:50 PM | #7 |
No hot wire... stock profiles. Sensored mode. I forgot to back timing down before I put to in but I think it was only at 15.
06-09-2013, 10:00 PM | #8 |
15 degrees of timing or boost? Boost is better because it increases as the rpm increases. Borrow a hot wire and set c1 with 15 degrees boost and c2 with 25 degrees. Then you can change it on the trail Sent from my PG86100 with Tapatalk 2 I <3 Tekin |
point me in the right direction. - Similar Threads | ||||
Lipo Charger Advice. Please point me in the right direction. | mmatthews | Electronics | 3 | 05-18-2012 10:20 AM |
building an interior for my honcho point me in the right direction! | mtnbiker93 | Scale Accessories | 5 | 01-10-2010 08:26 AM |
A little advice/point in the reight direction - Cantilever system | craigrobbo | General Crawlers | 14 | 11-02-2008 12:27 AM |
Need a Little Direction | Hillbilly_Crawl | Newbie General | 10 | 09-26-2007 04:28 PM |
New at this, Need some direction | sprtn4x4cw | Newbie General | 8 | 03-10-2006 10:20 AM |
