07-19-2013, 12:45 PM | #1 |
Pebble Pounder Join Date: Jun 2007 Location: La plata
| Jtpappys Build Thread now with ROCKSTARS!!
Decided it was time for a build thread. I have had this one for a little while and decided to burn my wallet. Enough with the talking PICTURE time: Current Setup Front Axle Vanquish C-hubs Vanquish Knuckles Hitec Hs-7950th Servo Vanquish Drag Link Vanquish Tie Rod Vanquish Smooth Diff Cover Axial Universals Axial Servo Horn for Hitec Servo Vanquish Locker Vanquish servo mounts Vanquish servo clamps Vanquish straight axle Vanquish truss Axial HD gears DLUX steering bushings Rear Axle Vanquish Lockouts Vanquish Smooth Diff Covers Vanquish straight axles Vanquish Locker Vanquish truss Axial HD gears Axial axles Rolling Stock Axial Beadlocks (Upgrade coming as soon as Vanquish Releases rockstars) Rockstars now!!! 2.2 baja claws with stock foam. (about to which to pit bulls and custom foam) 475 Vanquish hubs Transmission Super Shafty Top shaft Limited edition VP trans case HR gear Set 6mm Outputs RRP 32 Pitch 56 tooth spur gear RRP 32 pitch 14 tooth pinion gear Driveshafts MIP CVD Driveshafts for AX10 without dig Traxxas driveshaft pins 6mm bore for 6mm outputs Suspension Vanquish Upper Links x 2 Vanquish Lower Links x 2 Stock shocks Chassis and Body Cut stock Frame Carter fab inner fenders Custom Top Stock Wraith Interior Vanquish 5" Light Bar Vanquish light bar mount silver Axial light buckets up front Axial Light buckets for use in rear light bar Power and Control Tekin Roc412 3100kv Motor Mamba Max Pro ESC Castle Creations BEC Futaba 4PL Last edited by rc crawler boy; 02-15-2014 at 01:30 PM. |
07-26-2013, 03:03 PM | #2 |
| Re: Jtpappys Build Thread |
07-27-2013, 03:49 PM | #3 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
Yea they look good!
07-28-2013, 12:38 AM | #4 |
Quarry Creeper Join Date: Aug 2012 Location: Melbourne
Oh geez that's a good lookin rig!
07-28-2013, 04:53 AM | #5 |
Fifth dimension Join Date: Oct 2012 Location: Quakertown
Very nice!!
07-28-2013, 05:17 AM | #6 |
Rock Crawler Join Date: Sep 2008 Location: Nashua,NH
Looking good. I hear you on putting a hole in the wallet too.
07-28-2013, 06:27 AM | #7 |
| Re: Jtpappys Build Thread Thank you all for the nice comments i am researching camera equipment so that i can take better pictures for yall.
02-15-2014, 01:24 PM | #8 |
02-15-2014, 06:48 PM | #9 |
Rock Stacker Join Date: Jun 2013 Location: watertown
Great build. Money well spent.
02-15-2014, 08:34 PM | #10 |
Pebble Pounder Join Date: Sep 2013 Location: Fall River
Looks sick..... Silver sharpie those shift knobs ! Easy to do adds lots of detail , I also silver sharpied middle of my steering wheel
02-16-2014, 10:50 AM | #11 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
Nice build!
02-16-2014, 03:56 PM | #12 |
Got any hints on what to add now? vanquish rotors? shocks?
Jtpappys Build Thread - Similar Threads | ||||
Dual Dingo build thread-My first build thread | juswin24 | Axial SCX-10 | 205 | 09-19-2013 12:42 PM |
Swezy207's 2.2 scaler build! (first build thread) | swezy207 | 2.2 Scale Rigs | 43 | 09-19-2011 07:01 PM |
another jeep tj build (and my first build thread) | scorpion/king | 2.2 Scale Rigs | 5 | 12-18-2009 02:04 PM |
My first berg build (my first build thread) | jdacus | EnRoute Berg | 106 | 07-26-2009 07:29 PM |
not really a build thread more of a upgrade thread... | dragit | Axial AX-10 Scorpion | 16 | 07-02-2009 10:11 PM |
