03-24-2014, 04:18 PM | #21 |
Pebble Pounder Join Date: Dec 2013 Location: Island County
| Re: RCCrawler.com inspired Wraith
This looks totally boss. Love the attention to detail. Echo shortbus' compliments on the RX engine box.
03-24-2014, 05:01 PM | #22 |
Pebble Pounder Join Date: Oct 2010 Location: Cincinnati
Thanks for the compliments. And you're right, modding is never done. Just on hiatus for the moment Sent from my SGH-T769 using Tapatalk |
03-26-2014, 10:01 PM | #23 |
Newbie Join Date: Jan 2014 Location: Santa Cruz (SCM)
What drive shafts are you running, fantastic build
03-29-2014, 07:30 AM | #24 |
thanks. they are the super punisher from rc4wd Sent from my SGH-T769 using Tapatalk |
03-29-2014, 10:42 AM | #25 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
Got my STRC Chassis mounted servo / Panhard kit today. Because I do mostly crawling with my rig I've decided to attempt your truss mod. Got any advice before I do?
03-30-2014, 05:17 PM | #26 |
depending on what upper link you are using, the able may be clocked to far forward. easiest way to tell if its too much is by the drive shaft angle. if its straight you run the risk of rolling the axle under hard breaking. just make sure the drive shaft still has a slight angle. you may have to shorten the upper link a little Sent from my SGH-T769 using Tapatalk |
03-30-2014, 05:19 PM | #27 |
my pics are before the test runs when I ran into this issue. originally had the vanquish bent titanium upper link but had to go to a straight aluminum axial. Sent from my SGH-T769 using Tapatalk |
03-30-2014, 05:45 PM | #28 |
Good to know. I've got the Vanquish bent uppers on it at the moment, but do have the straight axial links if needed. We'll see.
03-30-2014, 05:59 PM | #29 |
you may have to notch the truss where the link rod end will be. it has slight contact there so I notched it to reduce unnecessary wear Sent from my SGH-T769 using Tapatalk |
RCCrawler.com inspired Wraith - Similar Threads | ||||
"RCC inspired Terra Wraith" | redsawacs | Axial Wraith | 23 | 12-31-2013 08:26 PM |
S&N FAB inspired wraith | BrainDead | Axial Wraith | 18 | 07-02-2012 10:47 AM |
blacrubi's KOH Inspired Wraith | blacrubi | Axial Wraith | 4 | 04-13-2012 03:18 PM |
Inspired 2.2 | jagg | Tamiya Clod Buster | 7 | 08-18-2008 07:37 AM |
